High Availability Monitoring(Host cluster)
vinayvemula
Post by vinayvemula »
Hi Team,
We have a requirement to monitor 2 Linux hosts which are running in high availability. Could you please advise us on monitoring of High availability hosts (Host cluster monitoring solution).
Re: High Availability Monitoring(Host cluster)
This depends on what you want to monitor, and how.
Many organizations choose to monitor each of the servers in the cluster independently, and then use a BPI group to monitor and do notifications on the cluster as a whole
https://assets.nagios.com/downloads/nag ... BPI_v2.pdf
vinayvemula
Thank you for the workaround!!
When we tested BPI in our NagiosXI using 2 host status. BPI status is not changing from Green even when 2 hosts were down. May I know what could be the possible cause. I have used Critical threshold as 25% as we need alert when both the servers were down and don't want any alert if one of the server is down. Please find the image
mbellerue
Post by mbellerue »
We might need a profile for this one. Can you download a profile and PM it to me? You can get a profile from Admin -> System Profile -> Download Profile.
