POP and IMAP Service shows error
ramachandrank
Post by ramachandrank »
Hi Team,
I have an exchange server and both POP and IMAP service running without any issues.
However, nagios showing critical on these 2 services alone.
Apart from these services, all others are showing normal.
Please help.
Ram
Re: POP and IMAP Service shows error
Post by Box293 »
Can you go into Core Configuration manager and edit these services. Click the "Run Check Command" button and then click the "Run Check Command" button on the new window that appears. Please post all of the output here.
