wproc: GLOBAL SERVICE EVENTHANDLER job 33714 from worker Cor
I am currently on Nagios XI 5.6.10, Yesterday i received a lot of recovery alerts from NagiosXI, for which i didn't receive any critical alerts.
when i run reports by host on Notifications i see both critical and recovery alerts alerts were sent.
FYI, I have database offloaded to a remote server.
When i check event log i see a lot of these errors,
wproc: early_timeout=0; exited_ok=1; wait_status=256; error_code=0;
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33714 from worker Core Worker 26873 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: stdout line 01: UNABLE TO CONNECT TO DB - EXITING!
Runtime Error 2020-02-05 20:52:07 wproc: early_timeout=0; exited_ok=1; wait_status=256; error_code=0;
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33711 from worker Core Worker 26873 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33715 from worker Core Worker 26873 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33713 from worker Core Worker 26880 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33712 from worker Core Worker 26880 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33710 from worker Core Worker 26880 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33694 from worker Core Worker 26878 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL HOST EVENTHANDLER job 33709 from worker Core Worker 26878 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33694 from worker Core Worker 26877 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33715 from worker Core Worker 26875 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33712 from worker Core Worker 26876 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33714 from worker Core Worker 26881 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33711 from worker Core Worker 26875 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33713 from worker Core Worker 26882 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33711 from worker Core Worker 26882 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33701 from worker Core Worker 26882 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33711 from worker Core Worker 26883 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33715 from worker Core Worker 26883 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33714 from worker Core Worker 26883 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33713 from worker Core Worker 26876 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33702 from worker Core Worker 26876 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33711 from worker Core Worker 26876 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33710 from worker Core Worker 26876 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33710 from worker Core Worker 26881 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33694 from worker Core Worker 26881 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: host=ssc-prd-mail-auth-046.ssa.gov; service=(none); contact=432530
Runtime Error 2020-02-05 20:52:07 wproc: NOTIFY job 33709 from worker Core Worker 26881 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33712 from worker Core Worker 26874 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33710 from worker Core Worker 26874 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33712 from worker Core Worker 26879 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33714 from worker Core Worker 26884 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: host=ssc-prd-mail-auth-046.ssa.gov; service=(none); contact=emsb_dl
Runtime Error 2020-02-05 20:52:07 wproc: NOTIFY job 33709 from worker Core Worker 26884 is a non-check helper but exited with return code 1
Runtime Error 2020-02-05 20:52:07 wproc: GLOBAL SERVICE EVENTHANDLER job 33715 from worker Core Worker 26877 is a non-check helper but exited with return code 1
Any idea on what these errors are, wproc: GLOBAL SERVICE EVENTHANDLER job * from worker Core Worker 26877 is a non-check helper but exited with return code 1
benjaminsmith
Re: wproc: GLOBAL SERVICE EVENTHANDLER job 33714 from worker
Thanks for posting the event log. Can you fetch the database log from the offloaded server and post it to the thread ( /var/log/mariadb/mariadb.log or /var/log/mysqld.log )?
Also, run the following command from the shell and post the output. Thanks.
echo "SELECT table_name AS 'Table', round(((data_length + index_length) / 1024 / 1024), 2) 'Size in MB' FROM information_schema.TABLES WHERE table_schema IN ('nagios', 'nagiosql', 'nagiosxi');" | mysql -uroot -pnagiosxi --table
# echo "SELECT table_name AS 'Table', round(((data_length + index_length) / 1024 / 1024), 2) 'Size in MB' FROM information_schema.TABLES WHERE table_schema IN ('nagios', 'nagiosql', 'nagiosxi');" | mysql -uroot -proot --table
| Table | Size in MB |
| nagios_acknowledgements | 0.20 |
| nagios_commands | 0.02 |
| nagios_commenthistory | 232.05 |
| nagios_comments | 0.09 |
| nagios_configfiles | 0.00 |
| nagios_configfilevariables | 0.01 |
| nagios_conninfo | 0.19 |
| nagios_contact_addresses | 0.00 |
| nagios_contact_notificationcommands | 0.02 |
| nagios_contactgroup_members | 0.00 |
| nagios_contactgroups | 0.00 |
| nagios_contactnotificationmethods | 1.59 |
| nagios_contactnotifications | 1.68 |
| nagios_contacts | 0.01 |
| nagios_contactstatus | 0.00 |
| nagios_customvariables | 0.24 |
| nagios_customvariablestatus | 0.24 |
| nagios_dbversion | 0.00 |
| nagios_downtimehistory | 2.00 |
| nagios_eventhandlers | 0.02 |
| nagios_externalcommands | 0.06 |
| nagios_flappinghistory | 0.21 |
| nagios_host_contactgroups | 0.01 |
| nagios_host_contacts | 0.01 |
| nagios_host_parenthosts | 0.00 |
| nagios_hostchecks | 0.00 |
| nagios_hostdependencies | 0.00 |
| nagios_hostescalation_contactgroups | 0.00 |
| nagios_hostescalation_contacts | 0.04 |
| nagios_hostescalations | 0.02 |
| nagios_hostgroup_members | 0.02 |
| nagios_hostgroups | 0.00 |
| nagios_hosts | 0.07 |
| nagios_hoststatus | 0.15 |
| nagios_instances | 0.00 |
| nagios_logentries | 120.32 |
| nagios_notifications | 1.56 |
| nagios_objects | 0.69 |
| nagios_processevents | 0.42 |
| nagios_programstatus | 0.00 |
| nagios_runtimevariables | 0.00 |
| nagios_scheduleddowntime | 0.00 |
| nagios_service_contactgroups | 0.00 |
| nagios_service_contacts | 0.40 |
| nagios_service_parentservices | 0.00 |
| nagios_servicechecks | 0.00 |
| nagios_servicedependencies | 0.00 |
| nagios_serviceescalation_contactgroups | 0.09 |
| nagios_serviceescalation_contacts | 0.42 |
| nagios_serviceescalations | 0.22 |
| nagios_servicegroup_members | 0.01 |
| nagios_servicegroups | 0.00 |
| nagios_services | 0.86 |
| nagios_servicestatus | 2.18 |
| nagios_statehistory | 7.12 |
| nagios_systemcommands | 0.04 |
| nagios_timedeventqueue | 0.00 |
| nagios_timedevents | 0.00 |
| nagios_timeperiod_timeranges | 0.02 |
| nagios_timeperiods | 0.01 |
| tbl_command | 0.06 |
| tbl_contact | 0.03 |
| tbl_contactgroup | 0.03 |
| tbl_contacttemplate | 0.03 |
| tbl_domain | 0.03 |
| tbl_host | 0.09 |
| tbl_hostdependency | 0.03 |
| tbl_hostescalation | 0.03 |
| tbl_hostextinfo | 0.03 |
| tbl_hostgroup | 0.03 |
| tbl_hosttemplate | 0.03 |
| tbl_info | 0.17 |
| tbl_lnkContactToCommandHost | 0.02 |
| tbl_lnkContactToCommandService | 0.02 |
| tbl_lnkContactToContactgroup | 0.02 |
| tbl_lnkContactToContacttemplate | 0.02 |
| tbl_lnkContactToVariabledefinition | 0.02 |
| tbl_lnkContactgroupToContact | 0.02 |
| tbl_lnkContactgroupToContactgroup | 0.02 |
| tbl_lnkContacttemplateToCommandHost | 0.02 |
| tbl_lnkContacttemplateToCommandService | 0.02 |
| tbl_lnkContacttemplateToContactgroup | 0.02 |
| tbl_lnkContacttemplateToContacttemplate | 0.02 |
| tbl_lnkContacttemplateToVariabledefinition | 0.02 |
| tbl_lnkHostToContact | 0.02 |
| tbl_lnkHostToContactgroup | 0.02 |
| tbl_lnkHostToHost | 0.02 |
| tbl_lnkHostToHostgroup | 0.02 |
| tbl_lnkHostToHosttemplate | 0.02 |
| tbl_lnkHostToVariabledefinition | 0.02 |
| tbl_lnkHostdependencyToHost_DH | 0.02 |
| tbl_lnkHostdependencyToHost_H | 0.02 |
| tbl_lnkHostdependencyToHostgroup_DH | 0.02 |
| tbl_lnkHostdependencyToHostgroup_H | 0.02 |
| tbl_lnkHostescalationToContact | 0.02 |
| tbl_lnkHostescalationToContactgroup | 0.02 |
| tbl_lnkHostescalationToHost | 0.02 |
| tbl_lnkHostescalationToHostgroup | 0.02 |
| tbl_lnkHostgroupToHost | 0.02 |
| tbl_lnkHostgroupToHostgroup | 0.02 |
| tbl_lnkHosttemplateToContact | 0.02 |
| tbl_lnkHosttemplateToContactgroup | 0.02 |
| tbl_lnkHosttemplateToHost | 0.02 |
| tbl_lnkHosttemplateToHostgroup | 0.02 |
| tbl_lnkHosttemplateToHosttemplate | 0.02 |
| tbl_lnkHosttemplateToVariabledefinition | 0.02 |
| tbl_lnkServiceToContact | 0.09 |
| tbl_lnkServiceToContactgroup | 0.02 |
| tbl_lnkServiceToHost | 0.16 |
| tbl_lnkServiceToHostgroup | 0.02 |
| tbl_lnkServiceToServicegroup | 0.02 |
| tbl_lnkServiceToServicetemplate | 0.06 |
| tbl_lnkServiceToVariabledefinition | 0.06 |
| tbl_lnkServicedependencyToHost_DH | 0.02 |
| tbl_lnkServicedependencyToHost_H | 0.02 |
| tbl_lnkServicedependencyToHostgroup_DH | 0.02 |
| tbl_lnkServicedependencyToHostgroup_H | 0.02 |
| tbl_lnkServicedependencyToService_DS | 0.02 |
| tbl_lnkServicedependencyToService_S | 0.02 |
| tbl_lnkServicedependencyToServicegroup_DS | 0.02 |
| tbl_lnkServicedependencyToServicegroup_S | 0.02 |
| tbl_lnkServiceescalationToContact | 0.02 |
| tbl_lnkServiceescalationToContactgroup | 0.02 |
| tbl_lnkServiceescalationToHost | 0.11 |
| tbl_lnkServiceescalationToHostgroup | 0.02 |
| tbl_lnkServiceescalationToService | 0.02 |
| tbl_lnkServiceescalationToServicegroup | 0.02 |
| tbl_lnkServicegroupToService | 0.02 |
| tbl_lnkServicegroupToServicegroup | 0.02 |
| tbl_lnkServicetemplateToContact | 0.02 |
| tbl_lnkServicetemplateToContactgroup | 0.02 |
| tbl_lnkServicetemplateToHost | 0.02 |
| tbl_lnkServicetemplateToHostgroup | 0.02 |
| tbl_lnkServicetemplateToServicegroup | 0.02 |
| tbl_lnkServicetemplateToServicetemplate | 0.02 |
| tbl_lnkServicetemplateToVariabledefinition | 0.02 |
| tbl_lnkTimeperiodToTimeperiod | 0.02 |
| tbl_logbook | 0.02 |
| tbl_mainmenu | 0.02 |
| tbl_permission | 0.28 |
| tbl_permission_inactive | 0.02 |
| tbl_service | 0.27 |
| tbl_servicedependency | 0.03 |
| tbl_serviceescalation | 0.03 |
| tbl_serviceextinfo | 0.03 |
| tbl_servicegroup | 0.03 |
| tbl_servicetemplate | 0.03 |
| tbl_session | 0.02 |
| tbl_session_locks | 0.02 |
| tbl_settings | 0.03 |
| tbl_submenu | 0.02 |
| tbl_timedefinition | 0.05 |
| tbl_timeperiod | 0.03 |
| tbl_user | 0.03 |
| tbl_variabledefinition | 0.09 |
| xi_auditlog | 3.81 |
| xi_auth_tokens | 1.61 |
| xi_cmp_trapdata | 0.03 |
| xi_cmp_trapdata_log | 0.03 |
| xi_commands | 0.02 |
| xi_eventqueue | 0.03 |
| xi_events | 0.05 |
| xi_incidents | 0.02 |
| xi_meta | 0.47 |
| xi_mibs | 0.05 |
| xi_options | 0.03 |
| xi_sessions | 0.03 |
| xi_sysstat | 0.03 |
| xi_usermeta | 1.55 |
| xi_users | 0.03 |
Also i sent mariadb.log in PM, please see PM. Please let me know if you need more information
| tbl_domain | 0.03 |
| tbl_host | 0.09 |
| tbl_info | 0.17 |
| tbl_user | 0.03 |
| xi_events | 0.05 |
| xi_meta | 0.47 |
| xi_mibs | 0.05 |
| xi_options | 0.03 |
| xi_sysstat | 0.03 |
| xi_users | 0.03 |
benjaminsmith
Thanks for sending over the log. There some InnoDB issues with several tables. Log into the shell on the XI server as root and run the following command and let us know if the issue is resolved.
/usr/local/nagiosxi/scripts/repair_databases.sh
please see attachment with results of repair_databases.sh
benjaminsmith
Hello @ISSB_MAOST,
The database tables look good. We'll have to review the nagios configs and logs to further troubleshoot. What is the exact name of the host or service sending out the recovery alerts?
Please send over the system profile and the notification report for the host. Thanks.
To send us your system profile.
Login to the Nagios XI GUI using a web browser
Save the profile.zip file and share this in a private message and then reply to this post to bring it up in the queue.
There are multiple hosts, which user didn't receive critical alerts but only recovery alerts. i have sent you PM with the profile and notifications report
benjaminsmith
Thanks for sending the files over.There numerous services to getting check results with the following error.
Can you upload the nrpe.cfg on these systems? If they are using the same commands, the one configuration file will work. Here's a guide that explains the check commands in NRPE and how to pass arguments in the check commands in Nagios XI.
NRPE - Configuring NRPE Commands To Accept Arguments
Also, once making any corrections, test the check command from the command-line in Nagios XI to make sure it is working as expected.
Nagios XI - How To Test Check Commands From The Command-line
The check commands are not defined in the nrpe.cfg configuration file on the remote host or the nrpe service was not restarted after making changes.NRPE: Command 'check_disk' not defined
Please see PM.
benjaminsmith
I just replied to your PM.
