Im trialling nagiosXI and it isnt going very well. Everything was running alright until I tried to add a new hostgroup through the interface, this happened;
Checking services...
Error: Service check command 'check_xi_service_snmp' specified in service 'Battery Status' for host 'APC Smart-UPS 5000' not defined anywhere!
Error: Service check command 'check_xi_service_snmp' specified in service 'Output Load' for host 'APC Smart-UPS 5000' not defined anywhere!
Error: Service check command 'check_xi_service_snmp' specified in service 'Power State' for host 'APC Smart-UPS 5000' not defined anywhere!
Error: Service check command 'check_xi_service_snmp' specified in service 'Remaining Battery Charge' for host 'APC Smart-UPS 5000 AKL' not defined anywhere!
Error: Service check command 'check_xi_service_snmp' specified in service 'Replace Battery Flag' for host 'APC Smart-UPS 5000' not defined anywhere!
Error: Service check command 'check_xi_service_snmp' specified in service 'Battery Status' for host 'APC Smart-UPS 5000 ' not defined anywhere!
Warning: Service 'Battery Status' on host 'APC Smart-UPS 5000 ' has no default contacts or contactgroups defined!
Error: Service check command 'check_xi_service_snmp' specified in service 'Output Load' for host 'APC Smart-UPS 5000 ' not defined anywhere!
Warning: Service 'Output Load' on host 'APC Smart-UPS 5000 ' has no default contacts or contactgroups defined!
Error: Service check command 'check_xi_service_snmp' specified in service 'Power State' for host 'APC Smart-UPS 5000 ' not defined anywhere!
Warning: Service 'Power State' on host 'APC Smart-UPS 5000 ' has no default contacts or contactgroups defined!
Error: Service check command 'check_xi_service_snmp' specified in service 'Remaining Battery Charge' for host 'APC Smart-UPS 5000 ' not defined anywhere!
Warning: Service 'Remaining Battery Charge' on host 'APC Smart-UPS 5000 ' has no default contacts or contactgroups defined!
Error: Service check command 'check_xi_service_snmp' specified in service 'Replace Battery Flag' for host 'APC Smart-UPS 5000 ' not defined anywhere!
Warning: Service 'Replace Battery Flag' on host 'APC Smart-UPS 5000 ' has no default contacts or contactgroups defined!
Error: Service check command 'check_xi_service_snmp' specified in service 'Battery Status' for host 'APC Smart-UPS RT 5000 RM XL AKL' not defined anywhere!
Error: Service check command 'check_xi_service_snmp' specified in service 'Output Load' for host 'APC Smart-UPS RT 5000 RM XL AKL' not defined anywhere!
Error: Service check command 'check_xi_service_snmp' specified in service 'Power State' for host 'APC Smart-UPS RT 5000 RM XL AKL' not defined anywhere!
Error: Service check command 'check_xi_service_snmp' specified in service 'Remaining Battery Charge' for host 'APC Smart-UPS RT 5000 RM XL AKL' not defined anywhere!
Error: Service check command 'check_xi_service_snmp' specified in service 'Replace Battery Flag' for host 'APC Smart-UPS RT 5000 RM XL AKL' not defined anywhere!
Error: Service check command 'check_xi_service_snmp_win_load' specified in service 'CPU Usage' for host 'O-DR1' not defined anywhere!
Warning: Service 'CPU Usage' on host 'O-DR1' has no default contacts or contactgroups defined!
Error: Service check command 'check_xi_service_snmp_win_storage' specified in service 'Drive C: Disk Usage' for host 'O-DR1' not defined anywhere!
Warning: Service 'Drive C: Disk Usage' on host 'O-DR1' has no default contacts or contactgroups defined!
Error: Service check command 'check_xi_service_snmp_win_storage' specified in service 'Drive D: Disk Usage' for host 'O-DR1' not defined anywhere!
Warning: Service 'Drive D: Disk Usage' on host 'O-DR1' has no default contacts or contactgroups defined!
Error: Service check command 'check_xi_service_snmp_win_storage' specified in service 'Drive Z: Disk Usage' for host 'O-DR1' not defined anywhere!
Warning: Service 'Drive Z: Disk Usage' on host 'O-DR1' has no default contacts or contactgroups defined!
Error: Service check command 'check_xi_service_snmp_win_process' specified in service ' Movement v1.0b' for host 'O-DR1' not defined anywhere!
Warning: Service ' Movement v1.0b' on host 'O-DR1' has no default contacts or contactgroups defined!
Error: Service check command 'check_xi_service_snmp_win_process' specified in service 'SQL Server' for host 'O-DR1' not defined anywhere!
Warning: Service 'SQL Server' on host 'O-DR1' has no default contacts or contactgroups defined!
Error: Service check command 'check_xi_service_snmp_win_storage' specified in service 'Virtual Memory Usage' for host 'O-DR1' not defined anywhere!
Warning: Service 'Virtual Memory Usage' on host 'O-DR1' has no default contacts or contactgroups defined!
Error: Service check command 'check_xi_service_snmp_win_load' specified in service 'CPU Usage' for host 'O-SAFE1' not defined anywhere!
Warning: Service 'CPU Usage' on host 'O-SAFE1' has no default contacts or contactgroups defined!
Error: Service check command 'check_xi_service_snmp_win_storage' specified in service 'Drive C: Disk Usage' for host 'O-SAFE1' not defined anywhere!
Warning: Service 'Drive C: Disk Usage' on host 'O-SAFE1' has no default contacts or contactgroups defined!
Error: Service check command 'check_xi_service_snmp_win_storage' specified in service 'Drive D: Disk Usage' for host 'O-SAFE1' not defined anywhere!Anyone? Thanks.
