solaris monitoring
progressive.nagiosXI
solaris monitoring
Post by progressive.nagiosXI »
Hi Team
we install ncpa on Solaris 10 server as per https://www.nagios.org/ncpa/getting-started.php#solaris
we dont know solaris 10 commands
  • how to check agent successfully installed or not
    how to change community_string (as done in centos via vim or vi editor)
    firewall rules if any
    restart the agent if needed
jdunitz
Re: solaris monitoring
Post by jdunitz »
For starters, there's a known issue with certain versions of NCPA on Solaris 10. Which version of the NCPA agent do you have? Yours may or may not be OK, so let us know what you have.
Most things on Solaris work pretty much the same as Linux, with a few differences.
# ls /usr/local/ncpa
Does it look like everything is in there?
# ps -efa | grep ncpa
Does ncpa appear to be running?
Also, if you hit https://your-solaris-machine.whatever.it.is:5693/ in a web browser, what do you see?
This is the same; vi works on Solaris the same way as linux.
I will refer you to this document:
https://docs.oracle.com/cd/E19253-01 ... ndex.html
# svcs -a | grep -i ncpa
# svcadm enable ncpa
# svcadm restart ncpa
If the output of svcs -a shows a different name for the ncpa service, use whatever is correct.
Hope that helps!
