SMS vs email
pspagnola
SMS vs email
Post by pspagnola »
Is it possible to setup some hosts to trigger SMS alerts and some to only trigger email alerts?
would I have to setup two accounts for each user to get this result?
Nagios v5.6.12 ~200 hosts 500+ services.
Re: SMS vs email
There is no way to specify the type of notification on the host level, only the user, so yes, you would need to create different user accounts for these.
pspagnola
Re: SMS vs email
Post by pspagnola »
thank you.
follow up question:
I am using AD integration for user authentication.
if I create a user jdoe and a second user jdoe-mobile can I have them both use the same AD authentication by using "jdoe" in the domain username box?
Re: SMS vs email
pspagnola wrote:thank you.
follow up question:
Unfortunately that wouldn't be possible
