ubable to connect from VMA to spefic host
I am trying to connect from VMA box and it shows the below error.
vi-admin@snagiosvra:~> ~/box293_check_vmware.pl --timeout 90 --concurrent_checks 50 --server invddsdsawe --check Host_CPU_Usage --host \"lab.test.com\"
UNKNOWN: Server version unavailable at 'https://invddsdsawe:443/sdk/vimService.wsdl' at /usr/lib/perl5/5.10.0/VMware/VICommon.pm line 726.
but for other servers, it's working only for some servers have this issue.
when I wget the page
vi-admin@snagiosvra:~> wget --no-check-certificate https://invddsdsawe:443/sdk/vimService.wsdl
--2020-02-24 15:32:52-- https://invddsdsawe/sdk/vimService.wsdl
Resolving invddsdsawe.. 11.62.12.10
Connecting to iinvddsdsawe|11.62.12.10|:443... connected.
Unable to establish SSL connection.
Below is the version
vi-admin@nagiosvra:~> perl -MLWP -le "print(LWP->VERSION)"
5.837
Firewall port and ping to the server is working from VMA. But when wget from the nagios server its downloading. Kinldy help us to fix this issue.
5.837
Re: ubable to connect from VMA to spefic host
I wonder if there is something wrong with the certificates. Run the following to get a packet capture and send it to me via a PM:
Let this run just long enought to run this command on another terminal:
Use CTRL+C to stop the tcpdump and PM me the output.pcap this created.
yum -y install tcpdump
tcpdump -s 0 -i any port 443 -w output.pcapCode: Select all
~/box293_check_vmware.pl --timeout 90 --concurrent_checks 50 --server invddsdsawe --check Host_CPU_Usage --host \"lab.test.com\"As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
I have sent you the tcpdump output. Kindly check it.
Response was sent yesterday. Please check your PMs.
It appears that a TCP connection is established but then the service closes the connection after snagiosvra sends the "Client Hello". snagiosvra is using TLS 1.0 . invddsdsawe may require a different version like 1.1, 1.2, or 1.3. Can you check the settings on this server?
Below is the details of the SSL from the server.
root@ [ ~ ]# openssl version
OpenSSL 1.0.2s-fips 28 May 2019
root@7[ ~ ]# openssl ciphers -v | awk '{print $2}' | sort | uniq
SSLv3
TLSv1.2
SSLv3
TLSv1.2
Which server exactly? The invddsdsawe machine? You may also need to look at the vm settings for this machine and not just the openssl version.
What does a working example look like? Can we get a command of a working example as well as a tcpdump to compare to the non-working?
Yes the invddsdsawe machine I have send you the tcpdump. kindly check it
You will want to look more into the servers since the working tcpdump shows the exact same 'client hello' as the non-working one. And despite openssl not showing support for TLS on the working machine, it is clearly negotiating a TLS connection with TLS ciphers.
Going back to the wget example you can try testing the protocols:
wget --no-check-certificate https://servernameorip:443/sdk/vimService.wsdl --secure-protocol=SSLv2
wget --no-check-certificate https://servernameorip:443/sdk/vimService.wsdl --secure-protocol=SSLv3
wget --no-check-certificate https://servernameorip:443/sdk/vimService.wsdl --secure-protocol=TLSv1
wget --no-check-certificate https://servernameorip:443/sdk/vimService.wsdl --secure-protocol=TLSv1_1
wget --no-check-certificate https://servernameorip:443/sdk/vimService.wsdl --secure-protocol=TLSv1_2As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
I have tried the wget command from the vma and all the wget result shows the same error.
