WARNING: RLIMIT_NPROC
steph007
Post by steph007 »
I have this warning in my Nagios log:
WARNING: RLIMIT_NPROC is 31329, total max estimated processes is 46568! You should increase your limits (ulimit -u, or limits.conf).
On this forum I've seen problem fixed by disable Deadpool, but it's already disable.
I have see problem that can be related to mysql connection, but event after change the default of 151 to 800, it's change nothing.
I still have the issues.
Where I can look next?
Re: WARNING: RLIMIT_NPROC
What OS and release is the Nagios server running?
What version of Nagios XI is the server running?
Edit the following file
/etc/security/limits.conf
Add the following to increase the limit for nproc.
*          soft     nproc          65535
*          hard     nproc          65535
Reboot the server and see if the issue goes away.
steph007
Post by steph007 »
My OS is CentOS release 6.10 and my Nagios XI release is 5.6.10
I did the change specified into your post and it's look ok now. Thanks!
benjaminsmith
Post by benjaminsmith »
Glad to hear that took care of it for you.
We'll close this out, but feel free to open another post if you have any new questions.
