SNMP Performance Data Graph Scale
GldRush98
Post by GldRush98 »
We have some SNMP checks set up that are monitoring data traffic for some virtual web sites.
We have the check working and we are getting performance data logged in to Nagios, but the unit of measurement is somewhat confusing.
The labels are simply "c". How can we configure a UOM on these services to something more logical like megabits per second, so that the graph shows this?
Here is an example of what we currently see:
And here is what one of the services looks like:
check_xi_service_snmp! -o .1.3.6.1.4.1.1991.1.1.4.25.1.1.7.10.10.98.149 -C activewebsite -P 2c -u Bytes -l Interface Traffic!!!!!!!
The unit there is specified as Bytes, but it doesn't appear to be graphing that way.
So, how can we change this?
Dev & Prod XI: Debian 12 - Nagios XI 2024R1.3
Re: SNMP Performance Data Graph Scale
If you go to the service detail page for this service on the advanced tab, what does it say under performance data:?
GldRush98
Post by GldRush98 »
Performance Data:iso.3.6.1.4.1.1991.1.1.4.25.1.1.7.10.10.98.142=2982558408c
performance data must be numeric, your has a c at the end
Post by Box293 »
I think that to change the performance data you need to use the -l (lowercase L) AND encapsulape the output in double quotes.
-l "Bytes"
check_xi_service_snmp! -o .1.3.6.1.4.1.1991.1.1.4.25.1.1.7.10.10.98.149 -C activewebsite -P 2c -u Bytes -l "Interface Traffic!!!!!!!"
or
check_xi_service_snmp! -o .1.3.6.1.4.1.1991.1.1.4.25.1.1.7.10.10.98.149 -C activewebsite -P 2c -u Bytes -l "Bytes"
Or for no label do
-l ""
check_xi_service_snmp! -o .1.3.6.1.4.1.1991.1.1.4.25.1.1.7.10.10.98.149 -C activewebsite -P 2c -u Bytes -l ""
GldRush98
Post by GldRush98 »
Ok, I'll give that a shot and post what works.
Is there no way to have it graph that bytes value as something more friendly like megabytes? I thought the graph would scale it accordingly... or maybe it will once it is receiving good data?
I have it updated and am just waiting for all new data to cycle in to see what it will do. I should have an answer tomorrow morning.
Post by Box293 »
How did you go with this? Did you get the result you were after?
GldRush98
Post by GldRush98 »
Sorry about not getting back sooner, but yes, I ended up using this one:
And that produced the output we were looking for. Thank you for your assistance. :)
