View Map cuts off
abishop
View Map cuts off
Post by abishop »
Is there a way to set the map in the views tab to actually fit on a screen? The Top, Right, and Bottom of my network map are cut off. I tried editing the /usr/local/nagiosxi/html/inlcudes/components/statusmap/index.php "resize_statusmap" and it doesn't seem to do anything to my map. Latest version of XI and using map 7.
Thank you.
benjaminsmith
Re: View Map cuts off
Post by benjaminsmith »
I would like to test this on my end, what layout setting for the status map are you using? Also, make sure the zoom settings for the browser (chrome: crtl +) are at 100%.
Lastly, if you can upload a screenshot of what you're seeing that would be great.
Thanks.
abishop
Post by abishop »
Zoom in Chrome was set to 100% we do have the map full screened. The header has, menu button, and help button are removed. Layout 7. I would send a screen shot if i could, our license just expired and I have to wait for the next fiscal year to buy it. Luckily that is in a couple of weeks. What I can say is that the top and bottom of my map, only half of the words were visible. On the top on the bottom half of the words were visible, the opposite for the bottom. I hope this helps!
Can you show us the actual URL that you are using in your view?
Views > Manage My Views > Edit View
I am not sure why you would not be able to take a screenshot... Even if you license is expired, you should be able to take a screenshot of the page. Am I missing something? I would be helpful to see what you see.
