Updated Nagios XI - check_http doesn't parse content with -s
ehumphries
Post by ehumphries »
We were running 2.2.1 of the nagios plugins yesterday. Updated Nagios XI, then updated the plugins.
[root@localhost ~]# /usr/local/nagios/libexec/check_http -V
check_http v2.3.2 (nagios-plugins 2.3.2)
Existing nagios check we had configured doesn't seem to be finding "SOMESTRING" in the page content any longer:
[root@localhost ~]# /usr/local/nagios/libexec/check_http -I 10.2.3.26 -s "SOMESTRING" -f ok -u "/users/sign_in" -w 5 -p 8080
HTTP CRITICAL: HTTP/1.1 200 OK - string 'SOMESTRING' not found on 'http://10.2.3.26:8080/users/sign_in', page size 8194 too small - 8194 bytes in 0.032 second response time |time=0.031728s;5.000000;;0.000000 size=8194B;8195;0;0
If i do the same thing with CURL, clearly SOMESTRING still exists in the page content:
[root@localhost ~]# curl http://10.2.3.26:8080/users/sign_in | grep "SOMESTRING"
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 29764 100 29764 0 0 985k 0 --:--:-- --:--:-- --:--:-- 1002k
<h6>SOMESTRING Phone</h6>
I've dug through the different available flags, and I haven't yet figured out any magic incantation that appears to fix this issue. What am I doing wrong? What else can I check?
pspagnola
Re: Updated Nagios XI - check_http doesn't parse content wit
Post by pspagnola »
I ran into a similar but different issues recently. The solution was to change the host address from the IP address to the DNS name, because the site was bound to the DNS name and not the IP address. I was getting a 304 redirect response.
During my troubleshooting I learned a few things. Inside of Core Configuration Manager (CCM) You can...
- on the service template screen, there is more that one check command for HTTP checking.
- There is a run check now command to help troubleshoot.
- you can adjust the ARGs and perform more tests.
sorry if you know all of this already.
The final working result for me was:
check command: check_xi_service_http
$USER1$/check_http -H $HOSTADDRESS$ $ARG1$
ARG1 = -s "string-to-check" -f ok -I hostname.domain.tld -u '/' -S --sni -p 443
Nagios v5.6.12 ~200 hosts 500+ services.
This was an issue identified in 2.3.2 and will be resolved in the next release.
https://github.com/nagios-plugins/nagio ... issues/535
As a word of caution, we do not recommend upgrading to the latest and "greatest" nagios-plugins open-source project for Nagios XI customers as issues like this can arise. When we deem the plugins version is fully stable it will be included in a Nagios XI release.
ehumphries
I appreciate your responses.
I only updated the plugins because our Nagios box hadn't been updated in a couple years. I wasn't sure if the plugins came with the standard update process. This isn't a large issue for us, I was just wondering what I did wrong. Will the fixed check_http plugin come down during the normal upgrade process in the future?
A good thing to note, is that check_http is the only plugin we're having issues with out of almost 600 different checks.
ehumphries wrote:Will the fixed check_http plugin come down during the normal upgrade process in the future?
It will once our team deems it "enterprise stable"
For now if you like, you can downgrade to 2.2.1
https://github.com/nagios-plugins/nagio ... s/releases
ehumphries
Thanks much!
ehumphries wrote:Thanks much!
No problem
Locking thread
