Unable to apply configuration.
fmomin
Post by fmomin »
Unable to apply any configuration on webinterface. giving below error.
[root@nagihpcorp01 ~]# /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 4.4.3
Last Modified: 2019-01-15
License: GPL
Reading configuration data...
Read main config file okay...
Error: Invalid max_check_attempts value for host 'APNETPUP031-new.ffx.jfh.com.au'
Error: Could not register host (config file '/usr/local/nagios/etc/hosts/APNETPUP031-new.ffx.jfh. com.au.cfg', starting on line 16)
directives and data definitions. If you are upgrading from a previous
Re: Unable to apply configuration.
Post by Box293 »
Can you try the steps in this KB article:
https://support.nagios.com/kb/article/n ... d-144.html
If this doesn't fix the issue then please list the steps you tried and what output you are getting.
