I am getting below error while installing nagios X1 on my CentOs machine.
Error: Package: nagiosxi-deps-el7-5.6.12-1.noarch (/nagiosxi-deps-el7-5.6.12-1.noarch)
Requires: perl-Net-SNMP
Requires: php-imap
Requires: php-mssql
Requires: perl(Crypt::Rijndael)
Requires: php-pecl-ssh2
Requires: perl(Class::Accessor)
Requires: python-pip
Requires: fping
Requires: perl-Mail-IMAPClient
Requires: perl-Math-Calc-Units
Requires: snmptt
Requires: python-pymssql
Requires: shellinabox
Requires: freetds-devel
Requires: freetds
Requires: perl-Number-Format
Requires: libmcrypt
Requires: libmcrypt-devel
Requires: python-simplejson
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './1-prereqs'
Kindly suggest..
Error while installing Nagios X1 on CentoOS
Re: Error while installing Nagios X1 on CentoOS
Is this server connected to the Internet with access to repositories?
If so, can you post the full install.log?
Yes server is connected to internet.
Attaching install.log here.
Can you show the output of the following on your system
yum provides perl-Net-SNMPRe: Error while installing Nagios X1 on CentoOS
[root@localhost opt]# yum provides perl-Net-SNMP
Loaded plugins: fastestmirror, langpacks
Loading mirror speeds from cached hostfile
* base: mirrors.praction.in
* extras: mirrors.praction.in
* updates: mirrors.praction.in
No matches found
No matches found
Looks like you don't have the epel repo enabled
Can you show the following
ll /etc/yum.repos.d
cat /etc/yum.repos.d/epel.repo
