From the help for the plugin
-c, --critical=THRESHOLD(s)
Critical threshold range(s)
so try
./check_snmp -C CMPublic -H 172.17.20.100 -o .1.3.6.1.4.1.318.1.1.13.3.4.1.3.1.0 -c 1
Full help
[root@localhost libexec]# ./check_snmp -h
check_snmp v2.2.1 (nagios-plugins 2.2.1)
Copyright (c) 1999-2014 Nagios Plugin Development Team
<[email protected]>
Check status of remote machines and obtain system information via SNMP
Usage:
check_snmp -H <ip_address> -o <OID> [-w warn_range] [-c crit_range]
[-C community] [-s string] [-r regex] [-R regexi] [-t timeout] [-e retries]
[-l label] [-u units] [-p port-number] [-d delimiter] [-D output-delimiter]
[-m miblist] [-P snmp version] [-N context] [-L seclevel] [-U secname]
[-a authproto] [-A authpasswd] [-x privproto] [-X privpasswd]
Options:
-h, --help
Print detailed help screen
-V, --version
Print version information
--extra-opts=[section][@file]
Read options from an ini file. See
https://www.nagios-plugins.org/doc/extra-opts.html
for usage and examples.
-4, --use-ipv4
Use IPv4 connection
-6, --use-ipv6
Use IPv6 connection
-H, --hostname=ADDRESS
Host name, IP Address, or unix socket (must be an absolute path)
-p, --port=INTEGER
Port number (default: 161)
-n, --next
Use SNMP GETNEXT instead of SNMP GET
-P, --protocol=[1|2c|3]
SNMP protocol version
-N, --context=CONTEXT
SNMPv3 context
-L, --seclevel=[noAuthNoPriv|authNoPriv|authPriv]
SNMPv3 securityLevel
-a, --authproto=[MD5|SHA]
SNMPv3 auth proto
-x, --privproto=[DES|AES]
SNMPv3 priv proto (default DES)
-C, --community=STRING
Optional community string for SNMP communication (default is "public")
-U, --secname=USERNAME
SNMPv3 username
-A, --authpassword=PASSWORD
SNMPv3 authentication password
-X, --privpasswd=PASSWORD
SNMPv3 privacy password
-o, --oid=OID(s)
Object identifier(s) or SNMP variables whose value you wish to query
-m, --miblist=STRING
List of MIBS to be loaded (default = none if using numeric OIDs or 'ALL'
for symbolic OIDs.)
-d, --delimiter=STRING
Delimiter to use when parsing returned data. Default is "="
Any data on the right hand side of the delimiter is considered
to be the data that should be used in the evaluation.
-w, --warning=THRESHOLD(s)
Warning threshold range(s)
--rate
Enable rate calculation. See 'Rate Calculation' below
--rate-multiplier
Converts rate per second. For example, set to 60 to convert to per minute
--offset=OFFSET
Add/substract the specified OFFSET to numeric sensor data
-s, --string=STRING
Return OK state (for that OID) if STRING is an exact match
-r, --ereg=REGEX
Return OK state (for that OID) if extended regular expression REGEX matches
-R, --eregi=REGEX
Return OK state (for that OID) if case-insensitive extended REGEX matches
--invert-search
Invert search result (CRITICAL if found)
-l, --label=STRING
Prefix label for output from plugin
-u, --units=STRING
Units label(s) for output data (e.g., 'sec.').
-D, --output-delimiter=STRING
Separates output on multiple OID requests
-t, --timeout=INTEGER:<timeout state>
Seconds before connection times out (default: 10)
Optional ":<timeout state>" can be a state integer (0,1,2,3) or a state STRING
-e, --retries=INTEGER
Number of retries to be used in the requests
-O, --perf-oids
Label performance data with OIDs instead of --label's
-v, --verbose
Show details for command-line debugging (Nagios may truncate output)
This plugin uses the 'snmpget' command included with the NET-SNMP package.
if you don't have the package installed, you will need to download it from
http://net-snmp.sourceforge.net before you can use this plugin.
Notes:
- Multiple OIDs (and labels) may be indicated by a comma or space-delimited
list (lists with internal spaces must be quoted).
- See:
https://www.nagios-plugins.org/doc/guidelines.html#THRESHOLDFORMAT
for THRESHOLD format and examples.
- When checking multiple OIDs, separate ranges by commas like '-w 1:10,1:,:20'
- Note that only one string and one regex may be checked at present
- All evaluation methods other than PR, STR, and SUBSTR expect that the value
returned from the SNMP query is an unsigned integer.
Rate Calculation:
In many places, SNMP returns counters that are only meaningful when
calculating the counter difference since the last check. check_snmp
saves the last state information in a file so that the rate per second
can be calculated. Use the --rate option to save state information.
On the first run, there will be no prior state - this will return with OK.
The state is uniquely determined by the arguments to the plugin, so
changing the arguments will create a new state file.
Send email to [email protected] if you have questions regarding use
of this software. To submit patches or suggest improvements, send email to
[email protected]
