Free Variables added via the API not showing up
optionstechnology
Post by optionstechnology »
Version 5.6.8
When I'm adding new hosats via the API I also add some custom free variables, they initially show up-
But then when I click on that its blank-
The code itself seems to be ok because it doesn't fail all of the time... 90% of the time its works fine and adds the variables
jdunitz
Re: Free Variables added via the API not showing up
Post by jdunitz »
That problem was a known issue which was fixed in 5.6.9.
If you're able, there have been at least a few other improvements in the last few months, and it might be worth updating to 5.6.12.
Thanks!
--Jeffrey
