Upgrade from 5.4.13 to 5.6.12 unsuccessful
Dave Ryan
Post by Dave Ryan »
I'm attempting to upgrade my Nagios XI instance from 5.4.13 to 5.6.12. However, the upgrade is failing (log attached). I also experienced issues on my last upgrade (see post https://support.nagios.com/forum/viewto ... 16&t=47882) but somehow the upgrade eventually went though even though it said it was unsuccessful.
Any ideas on what I should try to get this upgrade to go through successfully?
Dave.
Dave Ryan.
Re: Upgrade from 5.4.13 to 5.6.12 unsuccessful
Post by Box293 »
Could we get you to try the upgrade from a terminal session following the Manual Download method please:
https://assets.nagios.com/downloads/nag ... ctions.pdf
Dave Ryan
Post by Dave Ryan »
Thanks for the response. This is my production Nagios instance so I will attempt the Manual Download method after hours over the next day or so. Is there any added risk with upgrading using this method? I need to ensure that if the upgrade fails again that it will continue to operate successfully on the current 5.4.13 version. Thanks again.
Dave Ryan.
Dave Ryan wrote:This is my production Nagios instance so I will attempt the Manual Download method after hours over the next day or so. Is there any added risk with upgrading using this method?
No added risk, actually, I would recommend this.
Dave Ryan
Post by Dave Ryan »
I've attempted the Manual Download upgrade method however it still failed with a similar error message (Error: Nothing to do). Please see log attached.
Dave.
Dave Ryan.
That is strange it is cutting off like you are getting the error from the you command
Can you run the upgrade as follows and post the results
bash -x ./upgrade
Dave Ryan
Post by Dave Ryan »
Please find the log attached which used "bash -x ./upgrade"
Dave.
Dave Ryan.
For some reason your system cannot find the php-imap package
Lets run
yum clean all
And then lets see if we can get info on the package
yum provides php-imap
Dave Ryan
Post by Dave Ryan »
I've executed the commands, please see attached log.
Dave.
Dave Ryan.
it doesn't appear you have the optional channel enabled as it should be on a Nagios XI install
subscription-manager repos --enable rhel-6-server-optional-rpms
