Is it possible to create a SLA report on BPI groups? I can only see hosts, hostgroups and servicegroups as a criteria. What do I have to do, to get a BPI group centered SLA report?
Olaf
Re: BPI group centered SLA report
If you run the BPI Wizard for a BPI group, then you can view the newly created service in the SLA report.
Thanks, you showed me the solution. Works fine.
Great!enas wrote:Thanks, you showed me the solution. Works fine.
Locking thread
