Hi everyone
I try to understand a mistake :
I use an old pluggin called check_win_users (https://exchange.nagios.org/directory/P ... ck/details) to check the number of users on my RDP server.
if I execute the following command :
# su nagios /usr/lib/nagios/plugins/check_win_users.sh 172.16.0.12 NAGIOS 30 25 && echo $?
I've got this result :
4 users(s).
0
And this is perfectly correct.
But in Nagios, I've this :
"OK" -1 user(s).
Why does Nagios push "-1 user(s)." and not the result of the command as it does ?
The problem is only on the value of the result of the check commend, the rest ("user(s)") is in the echo like it does.
The following command works :
under root user or nagios user
expr $(snmpwalk 172.16.0.12 -v2c -c NAGIOS -Oqv 1.3.6.1.2.1.25.4.2.1.2 |grep winlogon.exe |wc -l) - 1
return 4
Here is the script :
#!/bin/bash
STATE_OK=0
STATE_WARNING=1
STATE_CRITICAL=2
STATE_UNKNOWN=3
STATE_DEPENDENT=4
nbUsers=`expr $(snmpwalk $1 -v2c -c $2 -Oqv 1.3.6.1.2.1.25.4.2.1.2 |grep winlogon.exe |wc -l) - 1`
if [[ $nbUsers -gt $3 ]]
then
echo "$nbUsers utilisateur(s)."
exit $STATE_CRITICAL;
else
if [[ $nbUsers -gt $4 ]]
then
exit $STATE_WARNING;
else
exit $STATE_OK;
fi
fi
exit $STATE_UNKNOWN;
Someone have an idea about this difference ?
thanks a lot
Difference beetween echo return and nagios shown
Re: Difference beetween echo return and nagios shown
Is the snmpwalk causing a time out? Find out how long it is taking:
The timeout can be adjusted on the snmpwalk command with the '-t' flag if needed.
The service check timeout is usually set to 60, but double check it in the nagios.cfg file. The directive would look like:
time snmpwalk 172.16.0.12 -v2c -c NAGIOS -Oqv 1.3.6.1.2.1.25.4.2.1.2 |grep winlogon.exe |wc -lThe service check timeout is usually set to 60, but double check it in the nagios.cfg file. The directive would look like:
service_check_timeout=60As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
