secure connection between Fusion to XI
This support forum board is for questions relating to Nagios Fusion.
elade
Re: secure connection between Fusion to XI
Post by elade »
Hi unfortunately I cant open remote session.
I did both SSL manuals for XI and Fusion with self signed certificate.
Close all HTTP communication between the 2 servers.
Still I can’t get fusion to fused this XI with https in the url section.
Telnet is working with port 443 from and to both servers.
Both servers are ubuntu 16 in AWS.
What logs/configuration or other info do you need in order to investigate?
ssax
Dreams In Code
Post by ssax »
Ok, that's definitely going to be a lot tougher.
Are you using a proxy in Admin > Proxy Configuration in your Fusion server?
When accessing the Fusion web interface, are you using http or https in the URL?
What do you have set for Admin > System Settings > Internal URL?
elade
Post by elade »
No
https:/serverip/nagiosxi/
both Fusion and XI are accessed in https
ssax
Dreams In Code
Post by ssax »
What version of XI is the server running exactly?
In the Nagios Fusion web interface go to Admin > System Settings:
- Set Log Level to trace
- Check the box next to Enable writing log data to the specified file
- Check the box next to Enable writing debug data to the specified file.
Then in that same SSH session, please run this command (as root) and LEAVE IT RUNNING:
tail -Fn0 /var/log/messages /var/log/cron /var/log/httpd/error_log /var/log/httpd/ssl_error_log /usr/local/nagiosfusion/var/log/*.log
Then go to Admin in the web interface and under the "Subsys Status" section, click the gear icon to the right of Polling Locks and then click the "Clear polling locks" button.
Now wait 10 minutes and send me the full output from the still running tail command above.
Click the Test Fusion Settings button while that tail command is still running as well.
Do you see anything standing out?
The only other thing I can think is if you hardened apache on the XI server or something.
elade
Post by elade »
I found out what was the problem and fixed it.
You can close the topic
Thank you!
ssax
Dreams In Code
Post by ssax »
Can you post what the resolution was so it can help us/and others in the future?
elade
Post by elade »
When I created the Certificate the Common Name must be an IP at least in my case.
elade wrote:When I created the Certificate the Common Name must be an IP at least in my case.
Great!
Locking
ahumandesign.com
enneagrams.com
