Website Config Wizard Bombs
katieKatiePants
Post by katieKatiePants »
Completed a HUGE amount of work today for our go-live tomorrow and the Very Last config is to use the website wizard to monitor an external address. Doesn't even need a token. Have attempted multple snapshot reversions, ensured any conflicting configs are deleted and just cannot get a successful verification from the website wizard. Furthermore, no awesome log messages / hints as to the resolution ... just a "Verification Failed" whimper. My kingdom for any awesome ideas!!!!! #whyIsItAlwaysTheSimpleThings #HTTPFTW
cdienger
Re: Website Config Wizard Bombs
Post by cdienger »
Can you provide a screenshot of the settings being used in the wizard? Does it work if you set up a really simple check for something like google?
Prior to using the wizard are you able to apply the config and get a successful verification?
Check the php.ini settings and adjust them according to https://support.nagios.com/kb/article/n ... e-611.html.
katieKatiePants
awesome reference! thank you!!
Were you able to resolve your issue or you are still getting "Verification Failed"? Let us know if it is safe to lock this topic.
