I've been searching all around but I wasn't able to find a proper answer. I have a proper Nagios setup monitoring my network (internal and external) but now I want to monitor the available disk space in my pi-hole.
As the pi-hole is a raspberry pi 1b+, it and has very limited resources. I though about using nrdp with passive monitoring in Nagios but I'm struggling.
I've configured Nagios as nrdp_server and configured check_dummy. It works.
my command configuration in Nagios machine is as follows:
define host {
use linux-server ; Host group to use
host_name pi-hole ; Name of this host
alias pihole ; Alias
address 192.168.1.x ; IP Address
use generic-service ; Name of service template to use
host_name pi-hole
service_description DNS
check_command check_dns
host_name pi-hole
service_description HTTP
check_command check_http
host_name pi-hole
service_description DHCP
check_command check_dhcp
host_name pi-hole
service_description Disk Usage
check_command check_dummy!2!"No results received"
active_checks_enabled 0
passive_checks_enabled 1
check_freshness 1
freshness_threshold 7200
notification_period 24x7
flap_detection_enabled 0
event_handler_enabled 0
notification_interval 1440
In raspberry-pi server (monitored machine):
crontab:
#!/bin/sh
df -H | grep -E $1 | awk '{ print $5 " " $1 }' | while read output;
do
usep=$(echo $output | awk '{ print $1}' | cut -d'%' -f1 )
partition=$(echo $output | awk '{ print $2 }' )
if [ $usep -ge $3 ]; then
php /usr/local/nrdp/clients/send_nrdp.php --url=http://balrog/nrdp/ --token=C4uu6YbpJIKyrK9qxH --host=pi-hole --service="Disk Usage" --state=2 --output="Running out of space \"$partition ($usep%)\" on $(hostname) as on $(date)"
else
if [ $usep -ge $2 ]; then
php /usr/local/nrdp/clients/send_nrdp.php --url=http://balrog/nrdp/ --token=C4uu6YbpJIKyrK9qxH --host=pi-hole --service="Disk Usage" --state=1 --output="Running out of space \"$partition ($usep%)\" on $(hostname) as on $(date)"
else
php /usr/local/nrdp/clients/send_nrdp.php --url=http://balrog/nrdp/ --token=C4uu6YbpJIKyrK9qxH --host=pi-hole --service="Disk Usage" --state=0 --output="Disk ok \"$partition ($usep%)\" on $(hostname) as on $(date)"
fi
fi
done
And pls let me know if you find a better solution!
