Disable notifications
igeoigeo
Post by igeoigeo »
I have disabled notifications for service/host (notifications_enabled = 0), but nagios still sends. Below is the configuration that I applied:
define host {
        host_name                       test.example.com
        address                         test.example.com
        notifications_enabled           0
        use                             linux-server
        check_command                   check_http_
        register                        1
        use                             local-service         ; Name of service template to use
        service_description             TEST
        notification_options            w,u,c,r                 ; Send notifications about warning, unknown, critical, and recovery events
        notification_interval           10                      ; Re-notify about service problems every 10 minutes
How can I overcome this issue?
thank you.
jbrunkow
Re: Disable notifications
Post by jbrunkow »
Did you restart the Nagios service after you changed the configuration? This action will apply new configuration.
service nagios restart
It is possible that the setting in that file is being overridden by another. Do you see any conflicting information in either the */nagios/var/status.dat or the */nagios/etc/*.cfg file on that server?
baboyo3029
Post by baboyo3029 »
igeoigeo wrote:Hello,
define host {
        use                             linux-server
        register                        1
thank you.
Hi buddy, it happens. Just restart everything so the system can apply and you are good to go.
regards,
B. Smith
benjaminsmith
Post by benjaminsmith »
Hi @baboyo3029 .
Just checking in, did you get it worked out? Let us know when you have a minute.
Benjamin
Nagios Support Team
igeoigeo
Post by igeoigeo »
it didn't work with the aforementioned way, so I managed to fix it by using the following configuration:
notification_options = n
we can close the this post.
thanks.
