On one of my servers, I am unable to comment and/or acknowledge on services. I'm not receiving any errors in the web interface, but nothing happens.
I saw that I was down to 4 GB of free space on my root partition, so I followed the directions expand it here: https://support.nagios.com/kb/article.php?id=814
I have also run /usr/local/nagiosxi/scripts/repair_databases.sh
Comments and Acknowledgements Not Working
Re: Comments and Acknowledgements Not Working
Please PM me a copy of your profile, you can download it from Admin > System Profile > Download Profile.
Attach the output of these commands as well:
Thank you
chage -l nagios
grep nag /etc/group
ls -lh /usr/local/nagios/var
ls -lh /usr/local/nagios/var/rwRe: Comments and Acknowledgements Not Working
I don't see anything in your profile that's standing out.
Please run these commands and let me know if that resolves your issue:
Additionally, please send the output of these commands (as root):
- NOTE: You may need to adjust the -h 127.0.0.1, the -uroot, and -pnagiosxi in the first command if your DB is offloaded to another server and/or you've changed the root mysql password
systemctl stop httpd
systemctl stop crond
systemctl stop npcd
systemctl stop nagios
systemctl stop ndo2db
pkill -9 -u nagios
pkill -9 -u apache
for i in $(ipcs -q | grep nagios |awk '{print $2}'); do ipcrm -q $i; done
rm -f /usr/local/nagiosxi/var/dbmaint.lock
rm -f /usr/local/nagiosxi/var/event_handler.lock
rm -f /usr/local/nagiosxi/scripts/reconfigure_nagios.lock
rm -f /usr/local/nagiosxi/tmp/reconfigure_nagios.lock
rm -f /usr/local/nagios/var/ndo2db.lock
rm -f /usr/local/nagios/var/ndo2db.pid
rm -f /usr/local/nagios/var/ndo2db.sock
rm -f /usr/local/nagios/var/ndo.sock
rm -f /us/local/nagiosxi/var/subsys/ndo2db
rm -f /var/run/nagios/nagios.lock
rm -f /var/run/nagios.lock
rm -f /usr/local/nagios/var/nagios.lock
rm -f /var/run/httpd/httpd.pid
systemctl restart mariadb
systemctl start ndo2db
systemctl start nagios
systemctl start npcd
systemctl start crond
systemctl restart httpd
systemctl restart snmptt- NOTE: You may need to adjust the -h 127.0.0.1, the -uroot, and -pnagiosxi in the first command if your DB is offloaded to another server and/or you've changed the root mysql password
echo "SELECT table_name AS 'Table', round(((data_length + index_length) / 1024 / 1024), 2) 'Size in MB' FROM information_schema.TABLES WHERE table_schema IN ('nagios', 'nagiosql', 'nagiosxi');" | mysql -h 127.0.0.1 -uroot -pnagiosxi --tableRe: Comments and Acknowledgements Not Working
First, login to the web interface as the nagiosadmin user.
Then edit your /usr/local/nagios/etc/cgi.cfgand change it to this:
Now edit any user in Admin > Manage Users, no need to make any changes, just click the Update User button.
Now apply config and everything should work, test and let us know the results.
# MODIFIED
default_statusmap_layout=6
# UNMODIFIED
action_url_target=_blank
authorized_for_all_host_commands=nagiosadmin
authorized_for_all_hosts=nagiosadmin
authorized_for_all_service_commands=nagiosadmin
authorized_for_all_services=nagiosadmin
authorized_for_configuration_information=nagiosadmin
authorized_for_system_commands=nagiosadmin
authorized_for_system_information=nagiosadmin
default_statuswrl_layout=4
escape_html_tags=0
lock_author_names=1
main_config_file=/usr/local/nagios/etc/nagios.cfg
notes_url_target=_blank
physical_html_path=/usr/local/nagios/share
ping_syntax=/bin/ping -n -U -c 5 $HOSTADDRESS$
refresh_rate=90
show_context_help=0
url_html_path=/nagios
use_authentication=1
use_pending_states=1
use_ssl_authentication=0Now apply config and everything should work, test and let us know the results.
That did the trick. Is this something that I should be concerned about with my other 7 instances?
I am glad your issue has been resolved! You shouldn't be concerned with your other 7 instances. If you run into any new issues, please start a new thread. Thank you!
