Howdy folks,
Has anyone had to make plugins compiled from source available to the web UI on XI? We have a closed network environment so we had to do the build of the Oracle and Vmware esxi plugins from source with all the relevant cpan modules. Now we just need to make them available for use in the web ui. However, We access the xi servers from a jump host and when we select browse to find the plugin the UI wants to look on the jump server not on the XI server where we have the plugins. Any thoughts?
Dan_F_DXC
Making plugins compiled from source accessible in the Web UI
Re: Making plugins compiled from source accessible in the We
I just want to clarify that the Browse button you are using is from the Admin > Manage Plugins menu, is that correct?
If so, that button does not browse the XI server, it browses the system that the Web Browser is running and in your case, it is the jump host.
You could copy the plugins to the jump hosts drive and then use the browse button to upload them to the XI server.
Or, you could just secure copy the plugins directly to the XI server in the closed network from a system that you can access, is that possible to do?
Yes the browse button on the web browser which is on the jump host. So we do have the plugins installed on the XI they just aren't showing up when you search for the plugin on the manage plugin page. I seem to have found the configuration wizards here:
https://hpsatvld5302.mgmt.sabre.com/nag ... config.php
So I am guessing we probably can configure monitoring on esxi and oracle servers. We are a bit new to this tool
Dan_F_DXC
Dan_F_DXC
The VMWare wizard uses this plugin
But, due to licensing, we cannot include the Oracle Instant Client and the VMWare Perl SDK but is you can manually install then, the existing plugins should function.
If you did get them installed, you should be able to use the Wizards to monitor your servers and databases.
and the Oracle wizards use this plugincheck_vmware_api.pl
Both of the plugins should be on the server.check_oracle_health
