storage monitor
progressive.nagiosXI
storage monitor
Hi Team,
please help how to monitor attached storage type via Nagiosxi.
we need to monitor these storage via gearman worker server.
Re: storage monitor
You will need to install/setup the plugins on the gearman worker and then add them into the XI system as commands to use:
You'll need to test out any plugins you find to see if they meet your needs.
I found these:
https://support.hpe.com/hpsc/swd/public ... b64c2e793e
https://exchange.nagios.org/directory/P ... pl/details
https://exchange.nagios.org/directory/P ... er/details
See here as well for all SAN/NAS plugins:
https://exchange.nagios.org/directory/P ... AN-and-NAS
Let us know if you have any problems/questions.
I found these:
https://exchange.nagios.org/directory/Plugins/Hardware/Storage-Systems/SAN-and-NAS/NetApphttps://exchange.nagios.org/directory/P ... AN-and-NAS
Re: storage monitor
Hi Team,
we tried with IBM-xiv and Dell EMC storage but not getting success.
device output response attached , Please help
Re: storage monitor
xcli not found.Otherwise, you'd need to install XCLI on the XI system:
https://www.ibm.com/support/knowledgece ... il_05.html
You will need to run the check_emc_clariion.pl check again, the file didn't exist:
-bash: ./check_ecm_clariion.pl: No such file or directory-
Re: storage monitor
Hi Team,
we are getting attached error ,Please help
EMC : error returned from management server.
XIV : getting data on nagios worker but error in NagiosXI server xcli not found.
on worker >>(we set nagios user path to xcli dir ,changed group of xcli files to nagios)
XCLi installed and configured on worker and successfully running.
Re: storage monitor
Does it work for both if you do this:
mv /home/nagios/xcli /usr/local/nagios/libexec/
chown apache.nagios /usr/local/nagios/libexec/xcli-
Re: storage monitor
Hi ,
file location and ownership changed getting check output on worker after changes without any error but still showing below error in Nagiosxi dashboard.
EMC storage still getting error
xcli not foundThanks
Re: storage monitor
When you say worker, is that a mod_gearman worker you are talking about?
Re: storage monitor
yes mod_gearman worker
Re: storage monitor
It kinda looks like the gearman worker isn't running it, do you have the groups setup so that the check goes to the gearman worker?
Please post your gearman worker's worker.conf and the /etc/mod_gearman2/module.conf file from your XI server.
Include a copy of your profile so that I can see how it's configured.
