I am new to Nagios and would like to know how can we do alert suppression\correlation in Nagios XI?
Thanks.
Alert suppression\correlation
Re: Alert suppression\correlation
Can you describe in a little more detail what you mean by "alert suppression\correlation"
What is happening now, and what would your desired results be?
This will help tremendously understanding what you would like to achieve
supriyadhat
If there is an issue with the server or any of the network device, it will generate hundreds of alerts and so will send these many notifications. Instead of sending too many emails\SMS, we want to send only 1/2 emails\SMS and suppress rest as support team aware of an issue.
Here alert suppression\correlation will be helpful to send less number of notifications to the support teams.
supriyadhat
If there is an issue with the server, application or any of the network device, there is possibility of generating hundreds of alerts and so send these many emails\SMS to support teams. If we use alert suppression\correlation, it will show 1/2 alerts in the console and suppress rest. Even support team won't receive too many alerts in this case.
So I would like to know if we have such provision in Nagios XI. If yes, how can we do it?
Thanks.
Thanks.
ajaysinghbisth
Hello
what should i need to do after installation of nsclient++ because i installed nsclient++ but after that nsclient does not show on taskbar.
Plz advise me
Plz advise me
If the team acknowledges the problem, alerts are suppressed.supriyadhat wrote:If there is an issue with the server or any of the network device, it will generate hundreds of alerts and so will send these many notifications. Instead of sending too many emails\SMS, we want to send only 1/2 emails\SMS and suppress rest as support team aware of an issue.
Additionally if you have many services to acknowledge you may want to install the mass acknowledge component to be able to acknowledge many things at once.
http://exchange.nagios.org/directory/Ad ... nt/details
NSClient runs as a background service, so it doesn't show in the taskbar. Configuration changes for the agent are in %PROGRAMFILES%\NSClient++\NSC.iniajaysinghbisth wrote:what should i need to do after installation of nsclient++ because i installed nsclient++ but after that nsclient does not show on taskbar.
ajaysinghbisth
Monitoring step
Hello
i would like monitor my desktop what i need to do first step and how can i see it is working.
Regards
Ajay Singh
Albion Global Pvt Ltd
Regards
Ajay Singh
ajaysinghbisth
what need to change this nsc.in file path is c:\programme file\nsclient++
This totally depends on what you want to monitor, a minimum is to add
allowed_hosts=
password=
and make sure NSClientListener.dll is not commented out
allowed_hosts=
password=
