Cloudera manager Integration with Nagios
ets_user
Post by ets_user »
We have a cloudera cluster with more than 50 nodes and we would like to Integrate with our Nagios monitoring system.
Pls guide us on how we can achieve it and also provide documentation links for the same to follow.
Thanks.
cdienger
Re: Cloudera manager Integration with Nagios
Post by cdienger »
Check out the plugins available at https://github.com/harisekhon/nagios-plugins for Cloudera. Documentation for these plugins can be found at https://github.com/HariSekhon/Nagios-Pl ... /README.md and integrating third party plugins like this can be done with the steps in
https://assets.nagios.com/downloads/nag ... ios-XI.pdf.
jdunitz
Post by jdunitz »
Depending on what specifc part of Cloudera you want to monitor, this might be a good place to start:
https://exchange.nagios.org/directory/P ... n)/details
If you can explain what you're looking for with little more detail, I might be able to help more.
--Jeffrey
