Hello XI support
Please advise if there is a way to email listed processes when using NCPA TOP Process check (since XI does not retain the list historically)
As attached, at a time of the triggered alerts, could we get the list of processes somehow recorded?
Thank you
NCPA Top CPU/Memory process to email the list?
Re: NCPA Top CPU/Memory process to email the list?
I believe that a little bit of bash could accomplish what you are talking about.
The greater than symbol will write text output from a command to a file.
Using two greater than signs in a command will add text output from a command to the end of a file specified.
You could schedule a job to repeat this process using something like cron in linux or a graphical interface like Nagios XI.
[ [i]command[/i] ] > [ [i]file name[/i] ]Code: Select all
[ [i]command[/i] ] >> [ [i]file name[/i] ]As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
