Could you help me how to create templates and add hosts using the created templates?
Bala
Nagios Xi templates
Re: Nagios Xi templates
If you navigate to the Configure section using the top bar of Nagios XI > click Core Config Manager under Advanced Configuration > then click Host Templates under Templates > you should see an + Add New button at the top of that page.
Please refer to the following linked document for more detailed information on how to manage hosts, hostgroups, and templates in XI.
https://assets.nagios.com/downloads/nag ... gement.pdf
Bala.Mutyam
Thanks for the update jbrunkow.
I'm little confused with adding hosts using templates. can you guide step by step process for add a host using customised template please?
Bala.Mutyam
Also for creating and adding hosts to service template please?
This document contains the corresponding information for services.
