Mod Gearman - Multi-Master
dbcummings
Post by dbcummings »
I am trying to get mod gearman to work where one worker is connected to multiple masters. However, when I connect one worker to two masters, the second master in the worker.conf file is the only one that will get jobs runs by the worker. Is it possible to have two masters connected to one worker?
DB
dbcummings
Re: Mod Gearman - Multi-Master
Addendum. I checked the worker log on the one that doesn't appear to be working. However, the log does seem to be showing the monitor checks. I am wondering if the worker is not reporting the results back to the servers. The host check returns this value:
(host check orphaned, is the mod-gearman worker on queue 'host' running?)
I took a look at the Mod Gearman documentation and what is says that is there are more than one server specified, it will send data to the first server available.
server
sets the address of your gearman job server. Can be specified more than once to add more server. Mod-Gearman uses the first server available.
There is an option in the worker configuration file called dupeservr.
dupserver
sets the address of gearman job server where duplicated result will be sent to. Can be specified more than once to add more server. Useful for duplicating results for a reporting installation or remote gui.
If you use this option, it looks like it will send the check results to a second server.
This may work for what you are looking for.
The worker gets the check from one gearman server, runs the check and returns the data to both.
See this link for more details.
https://labs.consol.de/nagios/mod-gearman/index.html
dbcummings
I tried the dup yesterday after opening the forum post and that seemed to "work". I will keep you posted.
dbcummings
I can do two, but no more. Even with two, the results don't seem to be predictable. Do you know if it is possible to install multiple workers on one physical server? I have a physical server I would like to use for multiple master servers.
I just want to clarify that you want to have one worker server setup to to get checks from two separate Gearman Servers, process the checks and send the data back to the server, is that correct?
You probably could do that is you create a separate worker.conf file called worker1.conf for example.
Create an init script or a .service file that loads a separate Gearman Work process that loads the worker1.conf file.
In theory it should work as the two Workers will only talk to their respective servers.
dbcummings
Great minds think alike. I want to do what you are describing and I am already testing what you described. I will let you know how it goes.
:D Yes, great minds do think alike at times. Let us know how it works out.
SteveBeauchemin
Post by SteveBeauchemin »
Beware - technical data follows.
I have many workers - all reply properly to the 3 core servers that send them tests.
-------- service file setup
On the mod_gearman workers.
In the /etc/systemd/system location I have 3 service files, one for each core server that sends tests. This avoids file name collisions.
(copied from /usr/lib/systemd/system and renamed and edited to fit my use)
This is one file.
cat mod-gearman-worker-core01.service
[Unit]
Description=Mod-Gearman Worker for core01
Documentation=http://mod-gearman.org/docs.html
After=network.target
[Service]
EnvironmentFile=/etc/sysconfig/mod-gearman-worker-core01
Type=forking
PIDFile=/var/mod_gearman/mod_gearman_worker-core01.pid
ExecStart=/usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/worker-core01.conf --pidfile=/var/mod_gearman/mod_gearman_worker-core01.pid
ExecReload=/bin/kill -HUP $MAINPID
User=nagios
Group=nagios
StandardOutput=journal
StandardError=inherit
[Install]
WantedBy=multi-user.target
------- start stop and status shell scripts
This is on the worker system.
I use systemctl to start and stop each mod_gearman.service. Via a shell script. Or I just cat the file and use the line I need.
I have 3 scripts, one each for start, stop, status on each worker.
cat nagios-start.sh
#!/bin/bash
# turn on echo mode
set -x
# Stop the services in the proper order
sudo systemctl start mod-gearman-worker-core01
sudo systemctl start mod-gearman-worker-core02
sudo systemctl start mod-gearman-worker-core03
# Finished
(I actually use:
sudo /usr/local/nagiosxi/scripts/manage_services.sh start mod-gearman-worker-core01
but systemctl is in the manage_services.sh script. - Explained at the bottom)
------------ mod_gearman conf files for each Nagios XI core server
I have 3 config files in /etc/mod_gearman
The files are identical except for the file names and core server IP. Each worker server has different setup but these 3 lines are the same.
worker-core01.conf
worker-core02.conf
worker-core03.conf
And each file has just those 3 lines different.
 logfile=/var/log/mod_gearman/mod_gearman_worker-core01.log
 logfile=/var/log/mod_gearman/mod_gearman_worker-core02.log
 logfile=/var/log/mod_gearman/mod_gearman_worker-core03.log
 server=[Core System 1 IP]:4730
 server=[Core System 2 IP]:4730
 server=[Core System 3 IP]:4730
 pidfile=/var/mod_gearman/mod_gearman_worker-core02.pid
 pidfile=/var/mod_gearman/mod_gearman_worker-core03.pid
This coexists perfectly on the workers and could probably support more core servers.
I run 10 workers presently and adding more soon.
In order to be able to force tests to specific workers, I set the worker configuration hostgroups and servicegroups like this
sample taken from /etc/mod_gearman/worker-core01.conf
# sets a list of hostgroups which this worker will work on.
# Either specify a comma separated list or use multiple lines.
hostgroups=Gearman-Only-Hosts
hostgroups=Gearman-Only-on-[This worker - each worker has a name that goes here per worker]
# sets a list of servicegroups which this worker will work on.
servicegroups=Gearman-Only-Services
servicegroups=Gearman-Service-on-[This worker - each worker has a name that goes here per worker]
The hostgroups and servicegroups match.
If I need a host and all it's services run from a specific worker, I add that Hostgroup to the Host definition.
If I need just one service to run from a specific worker - I edit the service and assign the Servicegroup
In general, I have 8 workers that are equal and can run all the tests. I let the core server send tests to all of them randomly.
I have some remote areas where I have a dedicated worker. Those tests can only run from that one worker.
Those hosts in that remote area have host definitions tied to the Hostgroup serviced by that specific mod_gearman worker.
---------------- Core server /etc/mod_gearman/module.conf file
The gearman module.conf file has all the hostgroups and all the servicegroups listed. like this... just a sample
Notice that I have Hostgroups matching Servicegroups so I can freely and easily assign tests where I need them
# sets a list of hostgroups which will go into separate queues
# Workers
hostgroups=Gearman-Only-on-[worker 1]
hostgroups=Gearman-Only-on-[worker 2]
hostgroups=Gearman-Only-on-[worker 3]
hostgroups=Gearman-Only-on-[worker 4] etc
# Core Server
hostgroups=Gearman-Only-on-core01
# Custom Groups
hostgroups=Gearman-Only-Hosts-custom
# Custom Worker
hostgroups=Gearman-Only-on-[worker 9]
# other Sites
hostgroups=Gearman-Only-Hosts-[worker 10]
# another Worker
hostgroups=Gearman-Only-on-VMG009001
# sets a list of servicegroups which will go into separate queues.
# Workers
servicegroups=Gearman-Service-on-[worker 1]
servicegroups=Gearman-Service-on-[worker 2]
servicegroups=Gearman-Service-on-[worker 3]
servicegroups=Gearman-Service-on-[worker 4] etc
# Core Server
servicegroups=Gearman-Service-on-core01
# Custom Groups
servicegroups=Gearman-Only-Services-custom
# Custom Worker
servicegroups=Gearman-Service-on-[Worker 9]
# other Sites
servicegroups=Gearman-Only-Services-[worker 10]
# another Worker
servicegroups=Gearman-Service-on-VMG009001
----------- Additional info - Management console
Congratulations for getting this far. It is a lot of data.
This data should get anyone going with multiple core servers (core server = one single Nagios XI host)
Of course I use the management component too. Each server can control its own config files remotely.
one example of 10 items...
Installation of this and getting shared keys in place is a whole other topic.
/usr/local/nagiosxi/html/includes/components/modgearmanxi/modgearmanxi.config.inc.php
    '[worker 1]' => array(
      'ip' =>'[actual IP]',
      'user' =>'nagios',
      'cfg' =>'/etc/mod_gearman/worker-core01.conf',
      'initd' =>'sudo systemctl status mod-gearman-worker-core01'
I actually use manage_services.sh but changed it to systemctl to make it easier for folks to understand.
this is my actual syntax
'initd' =>'sudo /usr/local/nagiosxi/scripts/manage_services.sh status mod-gearman-worker-core01'
---------- manage_services.sh changes to make management in a locked down environment work
And I have modified manage_services.sh to be able to run the commands.
changed 2 lines...
first=("start" "stop" "restart" "status" "reload" "checkconfig" "enable" "disable"
and
second=("httpd" "mysqld" "nagios" "ndo2db" "npcd" "snmptt" "crond" "snmptrapd" "gearmand" "rrdcached" "mod-gearman-worker" "firewalld")
----------------- apologies
Sorry if this is a lot to digest, but you should be able to run many core servers against many mod_gearman workers.
core server = Nagios XI server
Feel free to PM me if you need more data. I've been real busy over the last year but will try to be helpful.
Steve B
XI 5.7.3 / Core 4.4.6 / NagVis 1.9.8 / LiveStatus 1.5.0p11 / RRDCached 1.7.0 / Redis 3.2.8 /
SNMPTT / Gearman 0.33-7 / Mod_Gearman 3.0.7 / NLS 2.0.8 / NNA 2.3.1 /
NSClient 0.5.0 / NRPE Solaris 3.2.1 Linux 3.2.1 HPUX 3.2.1
dbcummings
Thank you. This is very helpful.
