Monitors to monitor the sql server database through Nagios
dbasupport
Post by dbasupport »
I would like which services or monitors which are critical and needs to monitor through Nagios for sql server database with their threshold .
For eg library cache hit ratio, buffer cache hit ratio.
jbrunkow
Re: Monitors to monitor the sql server database through Nag
Post by jbrunkow »
The optimum hit ratio for a database server is a highly debated subject, and depends on your system as well. Many systems administrators choose to use other metrics to measure the load on a particular server. What services are considered critical is also debated among systems administrators.
If you are unsure of what to set these ratios, you could just leave the default value in place. If that value produces to many unwanted alarms, you could dial it back.
dbasupport
Can I have the default value ,attached excel document has the default threshold which I got from configuration wizard .
Please let me know if these default values are good to configure in the Nagios , any recommended values .
ssax
Dreams In Code
Post by ssax »
I don't see anything attached.
These will differ per system, the defaults provided by the wizards are sane defaults but they may need to be adjusted per your environment. You can adjust them as needed.
The defaults were set by the developer of the wizard so they are the recommended defaults. We don't have any other threshold specific recommendations other than what the wizard defaults are. Just run through the wizards with the defaults, if you hit thresholds, increase them, then you will have a fine tuned system.
Let us know if you have any questions.
Thank you
