Hi Team,
I've noticed that the host drbpm02.nbf.ae is not a part of hostgroup EPH-PROD, but the hostname is showing under the same hostgroup in hostgroup overview section. What may be the issue? kindly advise?
There are few more hosts have the same issue.
Attached the screenshot for host as reference.
Incorrect hostgroup displayed for host in nagios
Re: Incorrect hostgroup displayed for host in nagios
If you go to Configure -> CCM -> Hostgroups -> EPH-PROD -> Edit
Click Manage Hosts button
Is this host listed there? If so you can remove it if you like.
If not, send us a profile.zip from Admin -> System Profile
There are many ways a host can become part of a hostgroup, through templating as well, we can help you search for this.
Hi Scottwilkerson ,
We don't see the host under hostgroup EPH-PROD.
I have sent you the system profile file separately. Please check.
Ok, looking at the profile this host group is being added to the xiwizard_linuxserver_host template
Remove it from there and Apply configuration and it should be removed
Hi Scott,
Thanks for your help. Issue got resolved.
Please close the thread.
Great!mejokj wrote:Hi Scott,
Locking thread
