After upgrade to 5.7
ivod
Post by ivod »
Hi Nagios team,
Yesterdays upgrade went smooth, and everything seems to be working, except SMS notification (but emails still comming in).
Checked localhost status , and warning appeared (attachment)
Can you tell me path/location, which parameter Im missing?
Faithfully, Ivo.
Re: After upgrade to 5.7
Because NDO3 replaces NDO2DB and the service/daemon for it no longer exists, the check is no longer necessary. You can remove the service check from your system. ...
In 5.7.1 we are going to change the plugin to remain OK but give a deprecated message ...
