All hosts/services in pending state after upgrade to 5.7
tpwebb
Post by tpwebb »
I have completed an upgrade to 5,7.0 and noticed I am getting a pending state for all hosts and services.
Thanks again for your help.
Profile is also attached.
tpwebb
Re: All hosts/services in pending state after upgrade to 5.7
Post by tpwebb »
Found this in another issue that appears similar
[root@nagios /]# mysql -uroot -pnagiosxi -h 127.0.0.1 nagios -e "ALTER TABLE nagios_hoststatus ADD check_options smallint(6) NOT NULL default '0' AFTER check_type";
ERROR 1060 (42S21) at line 1: Duplicate column name 'check_options'
[root@nagios /]# mysql -uroot -pnagiosxi -h 127.0.0.1 nagios -e "ALTER TABLE nagios_servicestatus ADD check_options smallint(6) NOT NULL default '0' AFTER check_type;"
Upgrading to Nagios XI 5.7.1, which was released yesterday, should fix your issue.
Here's the Nagios XI changelog:
https://www.nagios.com/downloads/nagios-xi/change-log/
tpwebb
Post by tpwebb »
Hello
I have upgraded to 5.7.1, this appears to have solve my issue for the pending state, although there is a lag before the information is presented on the dashboard.
I do have a new issue related to NRPE, I will log another request for this.
Terry
Hi Terry,
How much of a lag are you talking about? How large is your system (number of hosts & services)? Any additional information would help our developers with identifying, and fixing the issue. Thank you!
ajwilliamson
Post by ajwilliamson »
I'm seeing the same 'lag'.
I just added a couple of devices/services and it took about nine minutes for the Host/Service Status panels to show data.
I have 530+ hosts and 2100+ services being monitored.
Our developers believe that the lag is caused by truncating the status tables, and they are working on a fix. The issue should be resolved in the next release of Nagios XI.
tpwebb
Post by tpwebb »
for information sake, number of hosts is 975 and number of services are 8672
Thanks for looking into the issues
Regards
Terrence
Thanks for the info Terrence!
tpwebb
Post by tpwebb »
Do you have a proposed date for release of the next version with this fix in it?
Regards
Terrence
