Custom Logo
mneubauer
Custom Logo
Post by mneubauer »
Is there a document or instructions on how to change the Nagios Logo? I figured out how to change the background image but not sure how to do the logo. Thanks
Re: Custom Logo
mneubauer wrote:Is there a document or instructions on how to change the Nagios Logo? I figured out how to change the background image but not sure how to do the logo. Thanks
Yes
Admin -> System Extensions -> Manage Components -> Custom Logo -> Edit Setting icon
mneubauer
Re: Custom Logo
Post by mneubauer »
Yes
Thanks Scott. I don't see a System Extensions in the Admin tab
Re: Custom Logo
mneubauer
Re: Custom Logo
Post by mneubauer »
The only fields I have are:
System
Management
General
Re: Custom Logo
I'm so sorry, I somehow didn't catch this was the Nagios Log Server forum and was thinking Nagios XI.
At present, Nagios Log Server does not have a custom logo customization ability, but a feature request does exist for this and it may be added in the future.
mneubauer
Re: Custom Logo
Post by mneubauer »
scottwilkerson wrote:I'm so sorry, I somehow didn't catch this was the Nagios Log Server forum and was thinking Nagios XI.
Ok thank you
Re: Custom Logo
Ok thank you
No problem
Locking thread
