Is there a way to create a service escalation for all of my service groups only? Meaning no services, only groups.
When I try to make the Service Escalation with a Service Group attached to it only it gives me the following error:
Error: Service escalation host name or description is NULL
Error: Could not register service escalation (config file '/usr/local/nagios/etc/serviceescalations.cfg', starting on line 16)
Any advice would be appreciated.
Create Service Escalation for Service Group
Re: Create Service Escalation for Service Group
Have you entered a name and description for that host? Navigate to Configure using the bar on top > click Core Config Manager under Advanced Configuration on the left pane > then click Service Escalations >
What do you see on line 16 of your service escalations file?
If you have a name and description entered for the service group and that still doesn't work, you may want to try rewriting the configuration files.
- Navigate to Config using the bar on top of XI > click Core Config Manager under Advanced Configuration on the left pane > then click Config File Management under Tools on the left.
- Click Delete Files. ( Don't worry, we can easily rewrite them. )
- Click Write Configs.
- Click Verify Files. If you see any errors, correct them and perform the two previous steps again.
- Click Restart Nagios Core to apply the configuration.
