Hi ,
We are using the check_t plugin to monitor the page life expectancy performance counter for sql server database .
Getting critical alert , need some inputs to resolve this alert .
We have 4Gb physical memory for the server . From the below value 2811460.00 sec , I belive this the cumulative value .
I need to right threshold for critical and warning alert .
mssqldev01 View service status details for this host PerfMon MSSQL Buffer Mgr Page life expectancyDBA Team looking into the issueThis service problem has been acknowledged Critical 3d 8h 45m 42s 5/5 2020-07-06 12:29:51 MSSQL Buffer Mgr Page life expectancy = 2811460.00 sec
Page life expectancy critiacl alert
dbasupport
dbasupport
Re: Page life expectancy critiacl alert
This is the present setting which is set for PLE .
-l "\\SQLServer:Buffer Manager\\Page life expectancy","MSSQL Buffer Mgr Page life expectancy","sec" -w 86400 -c 172800!!!!!
benjaminsmith
Hi @dbasupport,
My apologies but I'm not familiar with check_t can you post a link to the plugin page or upload it to the thread and post the full check as well? Thanks, BenjaminWe are using the check_t plugin to monitor the page life expectancy performance counter for sql server database .
dbasupport
Sorry--- typo error ,its check_nt is the plugin
If it's regularly above the threshold you should increase the thresholds:
Thresholds really need to be tuned for your server, if that's a normal value returned then you'll need to increase the thresholds otherwise it will alert.
See here:
https://blog.sqlauthority.com/2010/12/1 ... e-counter/
https://www.sqlskills.com/blogs/paul/pa ... you-think/
http://houseofbrick.com/page-life-expec ... lling-you/
-l "\\SQLServer:Buffer Manager\\Page life expectancy","MSSQL Buffer Mgr Page life expectancy","sec" -w 2900000 -c 3200000!!!!!See here:
