Hello
Is it possible to change the default dir where the RRD files are stored.
I need to move all the file from the default dir /usr/local/nagios/share/perfdata to /opt/perfdata
BR
Change RRD files location
benjaminsmith
Re: Change RRD files location
Hi BR,
Generally speaking, we don't support customized file paths for Nagios XI. The software has many components and changing file paths can result in issues with these other components or upgrade failures, so this is not something we have documented or provide instructions for.
Let me know if you have any questions.
Thank you benjaminsmith. You can archive this post.
benjaminsmith
Hi @acedm,
Sounds good.
We'll close this out, but feel free to open another if you have any new questions.
Sounds good.
