Error: (0) json_encode(): Invalid UTF-8 sequence in argument
katronic
Post by katronic »
The following problem appeared after upgrading to Nagios 5.7.1. After entering Nagvis, on some maps I get the following error message:
URL: /nagvis/server/core/ajax_handler.php?mod=Map&act=getMapObjects&show=Mapa1&header_menu=1&hover_menu=1&context_menu=1&zoombar=1&zoom=100&_ajaxid=1594381825
File: /usr/local/nagvis/share/server/core/classes/NagVisMap.php
Line: 116
#0 [internal function]: nagvisExceptionErrorHandler(2, 'json_encode(): ...', '/usr/local/nagv...', 116, Array)
#1 /usr/local/nagvis/share/server/core/classes/NagVisMap.php(116): json_encode(Array)
#2 /usr/local/nagvis/share/server/core/classes/CoreModMap.php(322): NagVisMap->parseObjectsJson()
#3 /usr/local/nagvis/share/server/core/classes/CoreModMap.php(105): CoreModMap->getMapObjects()
#4 /usr/local/nagvis/share/server/core/functions/index.php(120): CoreModMap->handleAction()
#5 /usr/local/nagvis/share/server/core/ajax_handler.php(59): require('/usr/local/nagv...')
#6 {main}
result of the "locale" command:
LANG=pl_PL.UTF-8
LC_CTYPE="pl_PL.UTF-8"
LC_NUMERIC="pl_PL.UTF-8"
LC_TIME="pl_PL.UTF-8"
LC_COLLATE="pl_PL.UTF-8"
LC_MONETARY="pl_PL.UTF-8"
LC_MESSAGES="pl_PL.UTF-8"
LC_PAPER="pl_PL.UTF-8"
LC_NAME="pl_PL.UTF-8"
LC_ADDRESS="pl_PL.UTF-8"
LC_TELEPHONE="pl_PL.UTF-8"
LC_MEASUREMENT="pl_PL.UTF-8"
LC_IDENTIFICATION="pl_PL.UTF-8"
LC_ALL=
A request to help solve a problem...
benjaminsmith
Re: Error: (0) json_encode(): Invalid UTF-8 sequence in argu
Post by benjaminsmith »
Hi Katronic,
After researching the error, I found a similar support case that was resolved by the following change. Edit your /etc/my.cnf and under the [mysqld] section add this line:
init-connect='SET NAMES utf8'
Then restart the services:
systemctl stop nagios
systemctl restart mariadb
systemctl start nagios
And let me know if the problem is resolved. If not, revert the changes and send use your system profile. Thanks, Benjamin
To send us your system profile.
Login to the Nagios XI GUI using a web browser.
Save the profile.zip file and share in a private message or upload it to the post/ticket, and then reply to this post to bring it up in the queue.
katronic
Post by katronic »
I confirm that the problem has been resolved :)
Thank you very much for your help!
I am glad your issue has been resolved! I am closing this thread. Thank you!
