Oracle Query alert logic
raymond.therrien
Post by raymond.therrien »
I would like to change the [b]Oracle Query Wizard[/b] alert logic. It seems that it only operates on a 'Greater than, or equaled' logic, but there are some cases where I want to have it as 'equaled to' or 'Less than'. Is this possible? Right now I have to add CASE operators to my queries to avoid this.
select CASE WHEN count(*) = 0 THEN '1' WHEN count(*) > 0 THEN '0' END CASE from
-Ray
ssax
Dreams In Code
Re: Oracle Query alert logic
Post by ssax »
It looks like it supports the standard threshold format, see here:
https://nagios-plugins.org/doc/guidelin ... HOLDFORMAT
Try using the colon (:) after the value:
- Change X to the values you want
 --warning X: --critical X:
