Package installation error on nagios xi
a223163
Post by a223163 »
Having packages errors on the nagios xi installation. It seems there are missing packages but the weird thing is that it seems those packages are already installed. Should I use --skip-broken? Install log attached.
Re: Package installation error on nagios xi
It appears you have newer packages installed from a repo @centos-7-server-os_local than what is availab;e in the current repositories.
Also, it appears you have beta repositories enabled
Repository copr:copr.fedorainfracloud.org:rhscl:centos-release-scl is listed more than once in the configuration
Nagios XI is only support when installed on a clean minimal install.
Please start fresh from a clean minimal install and it should proceed as expected.
Finally, is there a reason you are starting an install with a version that is several years old ? Nagios XI 5.5.4 ?
a223163
Post by a223163 »
Thanks for the answer. I am gonna try installing it in a clean environment.
And the reason behind installing an older version is because I was trying to migrate an old instance we had to a new server. I was going to migrate first and then update. Would you recommend doing it the other way around?
a223163 wrote:And the reason behind installing an older version is because I was trying to migrate an old instance we had to a new server. I was going to migrate first and then update. Would you recommend doing it the other way around?
Either should work fine, but it is best that you do the backup/restore to the same version like you are doing.
