Upgrade Script Issues
dbcummings
Post by dbcummings »
I am trying to upgrade from Nagios 5.6.6 to 5.7.2 using the offline installer. The upgrade script is generating the following error:
package nagiosxi-shellinabox-5.7.2-2.el7.x86_64.rpm is not installed
Loaded plugins: langpacks
Examining nagiosxi-shellinabox-5.7.2-2.el7.x86_64.rpm: nagiosxi-shellinabox-5.7.2-2.el7.x86_64
Marking nagiosxi-shellinabox-5.7.2-2.el7.x86_64.rpm as an update to nagiosxi-shellinabox-5.6.6-1.el7.x86_64
Resolving Dependencies
--> Running transaction check
---> Package nagiosxi-shellinabox.x86_64 0:5.6.6-1.el7 will be updated
--> Processing Dependency: nagiosxi-shellinabox(x86-64) = 5.6.6-1.el7 for package: nagiosxi-5.6.6-1.el7.x86_64
---> Package nagiosxi-shellinabox.x86_64 0:5.7.2-2.el7 will be an update
Error: Package: nagiosxi-5.6.6-1.el7.x86_64 (@/nagiosxi-5.6.6-1.el7.x86_64)
Requires: nagiosxi-shellinabox(x86-64) = 5.6.6-1.el7
Removing: nagiosxi-shellinabox-5.6.6-1.el7.x86_64 (@/nagiosxi-shellinabox-5.6.6-1.el7.x86_64)
Updated By: nagiosxi-shellinabox-5.7.2-2.el7.x86_64 (/nagiosxi-shellinabox-5.7.2-2.el7.x86_64)
nagiosxi-shellinabox(x86-64) = 5.7.2-2.el7
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
Re: Upgrade Script Issues
I think there is a bug in the version of the offline installer you have
From the dir with the RPM's instead of running the upgrade script, run the following
yum -y --nogpgcheck localupdate *.rpm
dbcummings
Will there be a new offline installer package built? We are testing the upgrade process to certify it for our production upgrade. This is a big process and I want to test with the method we will use in production.
dbcummings wrote:Will there be a new offline installer package built? We are testing the upgrade process to certify it for our production upgrade. This is a big process and I want to test with the method we will use in production.
I've notified our dev team and after testing they will likely put out a new tarball.
I believe the upgrade script need to be changed to the following
#!/bin/sh -e
# Import gpg key
if [ ! -f /etc/pki/rpm-gpg/GPG-KEY-NAGIOS-V2 ]; then
	/bin/cp -f GPG-KEY-NAGIOS-V2 /etc/pki/rpm-gpg/GPG-KEY-NAGIOS-V2
	rpm --import GPG-KEY-NAGIOS-V2
fi
# Install packages that may not be installed yet
if ! rpm -q nagiosxi-shellinabox; then
	yum -y --nogpgcheck localinstall nagiosxi-shellinabox*.rpm
fi
if ! rpm -q nagiosxi-nxti; then
	yum -y --nogpgcheck localinstall nagiosxi-nxti*.rpm
fi
if ! rpm -q perl-Nagios-Monitoring-Plugin && ! grep -q '8.' /etc/redhat-release; then
	yum -y --nogpgcheck localinstall perl-Nagios-Monitoring-Plugin*.rpm
fi
# Do local install of packages
Our development team has tested and updated the tarball with the changes
https://repo.nagios.com/nagiosxi-offline/nagiosxi-5.7.2-2.el7.x86_64.tar.gz
dbcummings
I ran the script with this update. It was successful. However, there are issues with ndomod.o but I have opened another post on that.
#!/bin/sh -e
# Import gpg key
fi
fi
fi
fi
Thanks for confirming and opening a different thread for the new issue
Closing thread
