scheduled check does not work after reload nagios
el.tison
Post by el.tison »
Hello the support team,
Since the last update :
At each modification / reloading of the configuration, the "scheduled checks" are no longer updated and it is impossible to make "acknowledges".
It lasts about an hour and then returns to normal.
A repair of the base was made without resolving the problem.
Any idea where this might come from?
Version :
Nagios XI 5.7.2
CentOS 7
jbrunkow
Re: scheduled check does not work after reload nagios
Post by jbrunkow »
Just to be sure I'm clear on what's happening, you're trying to acknowledge an alert but can't after making changes in the Core Configuration Manager? It may take some time to rebuild the configuration, but an hour seems very long.
Can you please look to see if there are any errors in your configuration? Navigate to Configure section using the top bar of XI > click Core Config Manager under Advanced Configuration on the left pane > then click Config File Management under Tools on the left > and click the Verify Files button. If you see any errors, you can Delete Files then Write Configs and Restart Nagios Core to try to clear them.
It never hurts to send ( PM ) us a profile either! We can find lots of information about your system in there. You can download the profile by navigating to System Profile under System Config on the left pane > and clicking the Download Profile button on that page.
el.tison
Post by el.tison »
Hello jbrunkow,
Thank you for your reply.
I delete files then do a Write Configs: no error when I reload the nagios configuration.
I send you in PM the "system profile".
benjaminsmith
Post by benjaminsmith »
Thank you. We're reviewing the logs and we'll follow up with you shortly.
jbrunkow
Post by jbrunkow »
[1598511177] NDO-3: Query failed in ndo_empty_queue_timed_event
I see an error in your logs related to NDO failing. Please run through the following steps to downgrade that part for now. We are working on fixing this bug in the next version.
Downgrade Instructons (Local Database)
systemctl stop nagios
cd /tmp
rm -rf /tmp/nagiosxi
wget https://assets.nagios.com/downloads/nagiosxi/5/xi-5.6.14.tar.gz
tar zxf xi-5.6.14.tar.gz
cd /tmp/nagiosxi/subcomponents/ndoutils
./install
systemctl enable ndo2db
Then edit your /usr/local/nagios/etc/nagios.cfg and make sure this line is uncommented:
broker_module=/usr/local/nagios/bin/ndomod.o config_file=/usr/local/nagios/etc/ndomod.cfg
Make sure this line is commented:
#broker_module=/usr/local/nagios/bin/ndo.so /usr/local/nagios/etc/ndo.cfg
Then start the nagios service:
systemctl start nagios
el.tison
Post by el.tison »
Thank you very much, this solved the problem!
el.tison wrote:Thank you very much, this solved the problem!
Great!
Locking thread
