Website Checks
Website Checks
Hi Team,
We are using the check_http plugin to check the availability of websites.
There is no issue with the availability as we can browse them fine but the check keeps failing with a socket timeout error.
What can cause this and how can it be fixed?
Regards,
Rebecca Murray
Regards,
Rebecca Murray
Re: Website Checks
Hi Rebecca,
Do you get the timeouts when you run the check script from the command line, too? Or does this only happen when Nagios runs it?
--Jeffrey
--Jeffrey
Re: Website Checks
Hi Jeffrey,
The time out occurs when checking from command line as well.
Re: Website Checks
HI Rebecca,
If the failing checks are an intermittent issue, then it's likely the result of network congestion, try adding the -t 60 option to the plugin arguments, and let me know if that helps.
Re: Website Checks
Hi Benjamin,
We have set the timeout as 180 seconds.
It is still the same.
Re: Website Checks
Hi Rebbecca,
So it sounds like it's never returning a valid result, just getting the timeout error. Can you post the full check command to the thread for us to review?
Can you ping the address?
Are you using an IP address or hostname in the check command? If it's a hostname, is the address resolvable? Thanks, Benjamin
Is the hostname resolvable?
ping examplesite.com
nslookup examplesite.com
Re: Website Checks
Hi Benjamin,
The checks does give a valid output some times. See the below checks run from the command line:
[root@hostname ]# /$USER2$/check_http -t 180 -w 10 -c 15 --ssl -f follow -H 10.*.*.* -u https://vpn.domain.com
CRITICAL - Socket timeout after 180 seconds
[root@hostname ]# $USER2$/check_http -t 180 -w 10 -c 15 --ssl -f follow -H 10.*.*.* -u https://vpn.domain.com
HTTP OK: HTTP/1.1 200 OK - 6075 bytes in 0.062 second response time |time=0.061700s;10.000000;15.000000;0.000000 size=6075B;;;0
When I ping the address it gives 100% loss.
We are using the IP address in the command check not the hostname.
Re: Website Checks
To add to this the network team performed a packet capture to see if any drops but didn't find any drops or latency.
Re: Website Checks
Hi Rebbecca,
And then add the -v option for debug output, and post any error message to the thread. Thanks, Benjamin
If the network capture is good, but 100% packet loss on a ping, something is not quite right. Since you're using the IP address of the host instead, adjust your check_http command to use the -I option to avoid the DNS, for example:To add to this the network team performed a packet capture to see if any drops but didn't find any drops or latency.
/$USER2$/check_http -t 180 -w 10 -c 15 --ssl -f follow -I 10.*.*.* -u https://vpn.domain.com
/$USER2$/check_http -t 180 -w 10 -c 15 --ssl -f follow -I 10.*.*.* -u https://vpn.domain.com -v | less
Re: Website Checks
Hi Benjamin,
The command was successful the first time and then again threw a socket timeout error.
Working:
[root@hostname ~]# $USER2$/check_http -t 180 -w 10 -c 15 --ssl -f follow -I 10.*.*.* -u https://vpn.domain.com -v
GET https://vpn.domain.com HTTP/1.0
User-Agent: check_http/v2.0.3 (nagios-plugins 2.0.3)
Connection: close
Accept: */*
https://10.*.*.*:443https://vpn.domain.com is 263 characters
STATUS: HTTP/1.0 302 Found
**** HEADER ****
Server: BigIP
Cache-Control: no-cache, no-store
Connection: Close
Content-Length: 0
Set-Cookie: LastMRH_Session=ff19456e;path=/;secure
Set-Cookie: MRHSession=962183175d85d0f43a1b8959ff19456e;path=/;secure
**** CONTENT ****
Redirection to http://10.*.*.*:443/vdesk/hangup.php3
GET /vdesk/hangup.php3 HTTP/1.1
Connection: close
Host: 10.*.*.*
Accept: */*
https://10.*.*.*:443/vdesk/hangup.php3 is 5332 characters
STATUS: HTTP/1.1 200 OK
**** HEADER ****
Date: Thu, 03 Sep 2020 03:41:12 GMT
Server: BigIP
Content-Length: 4638
Connection: close
Content-Type: text/html; charset=utf-8
X-Frame-Options: DENY
Set-Cookie: MRHSession=deleted;expires=Thu, 01-Jan-1970 00:00:01 GMT;path=/
Set-Cookie: F5_ST=deleted;expires=Thu, 01-Jan-1970 00:00:01 GMT;path=/
Set-Cookie: MRHSHint=deleted;expires=Thu, 01-Jan-1970 00:00:01 GMT;path=/
Set-Cookie: F5_HT_shrinked=deleted;expires=Thu, 01-Jan-1970 00:00:01 GMT;path=/
Set-Cookie: F5_fullWT=deleted;expires=Thu, 01-Jan-1970 00:00:01 GMT;path=/
Set-Cookie: MRHSequence=deleted;expires=Thu, 01-Jan-1970 00:00:01 GMT;path=/
Pragma: no-cache
Cache-Control: no-cache, must-revalidate
**** CONTENT ****
<html>
<head>
<meta name="robots" content="noindex,nofollow">
<title>BIG-IP logout page</title>
<link rel="stylesheet" type="text/css" HREF="/public/include/css/apm.css">
<script src="/public/include/js/common.js" language="javascript"></script>
<script src="/public/include/js/u_plugin.js" language="javascript"></script>
<script language="javascript">
function InsertActivexControl(clsid, params)
var container = document.getElementById("logoutActivexContainer");
if (navigator.appName == "Microsoft Internet Explorer") {
var paramsCode = "";
for (var item in params) {
paramsCode += "<param name='" + item + "' value='" + params[item] + "'>";
container.innerHTML =
"<center><object classId=CLSID:" + clsid + " border=0 width=1 height=1>" +
paramsCode + "</object></center>";
else {
var pluginHost = new UPluginHost("", container);
var control = {"clsid": clsid, "width": 1, "height": 1};
pluginHost.hostControl(control, params);
function OnLoad()
var isBrowserControl = false;
try {
isBrowserControl = ("undefined" != typeof(window.external))
&& ("unknown" != typeof(window.external))
&& ("undefined" != typeof(window.external.WebLogonNotifyUser))
&& ("unknown" != typeof(window.external.WebLogonNotifyUser));
catch(e) {}
if(!isBrowserControl) {
document.getElementById("newSessionDIV").style.visibility = "visible";
try
if (get_cookie("F5_PWS") == "1")
document.cookie = "F5_PWS=0; path=/; expires=Fri, 01-Jan-1970 00:00:01 GMT";
var pwsClassId = "7E73BE8F-FD87-44EC-8E22-023D5FF960FF";
InsertActivexControl(pwsClassId, {"command": "exit"} );
}catch (e) {};
</script>
</head>
<body onload="OnLoad();">
<script>
try{
if(window.external && window.external.WebLogonOnAuthFailure) {
window.external.WebLogonOnAuthFailure();
}catch(e){};
try {
window.external.OnHostClose();
} catch(e) { }
</script>
<meta http-equiv="X-UA-Compatible" content="IE=Edge">
<meta name="viewport" id="viewport" content="initial-scale=1.0" />
<meta name="robots" context="noindex,nofollow">
//orientation toolbox
function setViewport(){
document.getElementById("viewport").setAttribute('content', Math.abs(window.orientation) == 90 ? 'width=device-height, initial-scale=1' : 'width=device-width, initial-scale=1.0' );
setViewport();
window.onorientationchange = function() {
setViewport();
</script>
<table id="page_header">
<tr >
<td id="header_leftcell"><img src='/public/images/customization/Common/PROD_RemoteUserVPN_vpn.domain.com_access_general_ui/logo_image_en.png'/></td>
<td id="header_rightcell"></td>
</tr>
<tr>
<td></td>
<td id="maxTimeoutTd"><span id="maxTimeoutTag" title=""></span></td>
</tr>
</table>
<noscript>
<div id="noscript_warning_red">JavaScript is not enabled. Please enable JavaScript in your browser or contact your system administrator for assistance.</div>
<div id="noscript_warning_newsession">To open a new session, please <A href="/">click here.</A></div>
</noscript>
<table id="main_table" class="logout_page">
<tr>
<td id="main_table_info_cell">
<table id="interaction_table">
<tr>
<td id="interaction_table_header">Your session is finished.</td>
</tr>
<tr>
<td class="interaction_table_option_cell"><br><DIV ID="sessionDIV" style='visibility:hidden' align=left></DIV>
Logged out successfully.<br> <br>Thank you for using BIG-IP.<br><br>
<div id="newSessionDIV" style='visibility:hidden'>To open a new session, please <A href='/'>click here.</A></div> </td>
</tr>
<tr>
<td class="interaction_table_footer"></td>
</tr>
</table>
</td>
<td id="main_table_image_cell"><img src="/public/images/my/tr.gif"></td></tr>
</table>
<div id="page_footer"><div>This product is licensed from F5 Networks. © 1999-2018 F5 Networks. All rights reserved. </div></div>
<DIV ID="logoutActivexContainer" class="inspectionHostDIVSmall"></DIV>
</body>
</html>
HTTP OK: HTTP/1.1 200 OK - 5332 bytes in 0.043 second response time |time=0.042636s;10.000000;15.000000;0.000000 size=5332B;;;0
Error:
Connection: close
Accept: */*
**** HEADER ****
Server: BigIP
Connection: Close
Content-Length: 0
Set-Cookie: LastMRH_Session=a9d75324;path=/;secure
Set-Cookie: MRHSession=4b2dd710bbb17eece760c2e4a9d75324;path=/;secure
**** CONTENT ****
Connection: close
Host: 10.*.*.*
Accept: */*
Working:
Connection: close
Accept: */*
**** HEADER ****
Server: BigIP
Connection: Close
Content-Length: 0
**** CONTENT ****
Connection: close
Host: 10.*.*.*
Accept: */*
**** HEADER ****
Server: BigIP
Connection: close
Pragma: no-cache
**** CONTENT ****
<html>
<head>
else {
function OnLoad()
try {
catch(e) {}
try
}catch (e) {};
</script>
</head>
<script>
try{
}catch(e){};
try {
} catch(e) { }
</script>
setViewport();
setViewport();
</script>
<tr >
</tr>
<tr>
<td></td>
</tr>
</table>
<noscript>
</noscript>
<tr>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
</table>
</td>
</table>
</body>
</html>
Error:
Connection: close
Accept: */*
**** HEADER ****
Server: BigIP
Connection: Close
Content-Length: 0
**** CONTENT ****
Connection: close
Host: 10.*.*.*
Accept: */*
