getting the below "undefined symbol error" on newly upgraded OS/PERL (see below for revs)... runs fine on old OS/PERL (see below for revs)... any suggestions? .... i removed the IP and user/password info for this post............ thanks, don
### ERROR MESSAGE ###
root@nagios:/usr/local/nagios/libexec# ./check_esx3-0.5.pl -D <ip address> -u 'testuser\nagios' -p 'password' -H <ip address -l cpu -s usage -w 80 -c 90
/usr/bin/perl: symbol lookup error: /usr/lib/perl/5.14/auto/Crypt/SSLeay/SSLeay.so: undefined symbol: Perl_Gthr_key_ptr
### NEW OS and PERL ###
root@nagios:/usr/local/nagios/libexec# uname -a
Linux nagios 3.2.0-24-generic #39-Ubuntu SMP Mon May 21 16:52:17 UTC 2012 x86_64 x86_64 x86_64 GNU/Linux
root@nagios:/usr/local/nagios/libexec# perl -v
This is perl 5, version 14, subversion 2 (v5.14.2) built for x86_64-linux-gnu-thread-multi
### OLD OS and PERL ###
root@oldnagios:/usr/local/nagios/libexec# uname -a
Linux oldnagios 2.6.32-32-server #62-Ubuntu SMP Wed Apr 20 22:07:43 UTC 2011 x86_64 GNU/Linux
root@oldnagios:/usr/local/nagios/libexec# perl -v
This is perl, v5.10.1 (*) built for x86_64-linux-gnu-thread-multi
check_esx3-0.5.pl ... undefined symbol error
Re: check_esx3-0.5.pl ... undefined symbol error
You are either missing the perl package Crypt::SSLeay package on your new server or you have a different incompatible version of it: http://search.cpan.org/~nanis/Crypt-SSL ... /SSLeay.pm
As long as it has internet access you can run the following to download and install it if it is missing: cpan Crypt::SSLeay
You can use the following one-liner to determine what version of the package you have on each:
It's also possible you are messing an OS dependency package... I can't remember what it's called exactly, something like libcrypt-devel.
perl -MFile::Find=find -MFile::Spec::Functions -Tlwe 'find { wanted => sub { print canonpath $_ if /\.pm\z/ }, no_chdir => 1 }, @INC' | grep CryptRe: check_esx3-0.5.pl ... undefined symbol error
ok, you nailed it, thank you so much....... fyi, after i got passed that, i got another error (below), but found a blog about inserting a line in the perl script, which fixed it.....so all is well, thanks again.
ERROR MSG
root@nagios:/usr/local/nagios/libexec# ./check_esx3-0.5.pl -D <ip address> -u 'testuser\nagios' -p 'password' -H <ip address> -l cpu -s usage -w 80 -c 90
CHECK_ESX.PL CRITICAL - Server version unavailable at 'https://172.18.18.120:443/sdk/vimService.wsdl' at /usr/share/perl/5.14/VMware/VICommon.pm line 545.
NEW LINE ADDED IN PERL SCRIPT
use Nagios::Plugin;
use File::Basename;
$ENV{PERL_LWP_SSL_VERIFY_HOSTNAME} = 0; <<<-------------- MUST BE AFTER "use File::Basename;"
ERROR MSG
use Nagios::Plugin;
use File::Basename;
Glad you found the solution
... I ran into the exact same error (having to set that environment variable) with the VMware plugin.
