AIX/VIO Services KPI Template
nike
Post by nike »
I have an Linux environment but now have been tasked to onboard 50 AIX/VIO servers.I am looking for advise on how to configure the AIX service KPI.
ssax
Dreams In Code
Re: AIX/VIO Services KPI Template
Post by ssax »
We do not have AIX/VIO servers here to test against so we do not have any sample configurations.
For AIX you can monitor through SSH and run plugins:
https://assets.nagios.com/downloads/nag ... ng_SSH.pdf
See here for the AIX plugins we have:
https://exchange.nagios.org/directory/P ... ystems/AIX
I would look at installing NCPA on the system, then you can use Configure > Config Wizards > NCPA wizard and should be able to check all of those though the integrated features of NCPA (which also lets you run plugins):
https://www.nagios.org/ncpa/getting-started.php#aix
See here as well:
https://assets.nagios.com/downloads/ncp ... -NCPA.pdf​
If not NCPA, you can also setup NRPE on the system, see here:
https://assets.nagios.com/downloads/nag ... _Agent.pdf
I do not see any VIO specific plugins available.
Let us know if you have any questions.
