Monitoring postgre - update /usr/bin/psql
steph007
Post by steph007 »
I'm trying to use check_postgres.pl to monitor some prostgres databases, but it's look like the version used for /usr/bin/psql is too old for our databases. How can I upgrade /usr/bin/psql?
Note
With verbose option used with check_postgres.pl, I can see the version of psql:
psql=/usr/bin/psql version=8.4
benjaminsmith
Re: Monitoring postgre - update /usr/bin/psql
Post by benjaminsmith »
What operating system are you using? Have you tried updating using the package manager?
Also, what type of error message are you getting when running the plugin? Can you post the output to the thread?
Thanks, Benjamin
steph007
Post by steph007 »
I'm on Nagios XI under CentOS 6.
I want use it to monitor some postgres database.
But when I use the version installed, I got an error for ssl connection.
We suspect that is because the version of the database is newer then the one installed on Nagios.
It seem that it's a entire postgres installed on Nagios. Is it used by Nagios? Why not just have deployed an client to connect/monitor postgres database?
The postgres db was used on older versions of Nagios XI and it would be still used if you upgraded from an old system.
Are you trying to monitor postgres on the same machine (with Nagios XI on it) or on a remote box? Can you show us a actual check that you are using run from the command line along with the output of it?
Nagios XI has 3 postgres wizards. Have you tried using any of them?
steph007
Post by steph007 »
Why which wizard is important?
The problem I have it's when I use check_postgres.pl to connect to my postgres database to monitor with ssl. When ssl is used, it's not working. When I don't used ssl, it's working. I think because /usr/bin/psql is ourdated compare to the database to monitor. Is it possible to update only /usr/bin/psql or we need to update all postgres on my Nagios XI?
I wouldn't say the wizards are "important" or "more important" than plugins, but they are easy to use, and are included in XI by default. Most users find them very useful.
Are you trying to monitor postgres on the same machine (with Nagios XI on it) or on a remote box? Can you show us both checks (working and not working), run from the command line along with the output of it?
We support the packages that are included by the OS. If you decide to upgrade a package to something newer than the OS provides, this would be out of the scope of Nagios support.
steph007
Post by steph007 »
I'm monitoring a remote postgres database.
This is a working trace, Without SSL:
root@plgesmon02[/root]# /usr/local/nagios/libexec/check_postgres.pl -H 10.211.209.164 --port=5439 --dbuser=nagios --dbname=postgres --dbpass="XXX" -v -v -v --action=connection
$POSTGRES1 = {
               "verbose" => 3,
               "test" => 0,
               "transform" => "",
               "dbpass" => [
                             "XXX"
               "showperf" => 1,
               "port" => [
                           5439
               "defaultport" => 5432,
               "dbname" => [
                             "postgres"
               "host" => [
                           "10.211.209.164"
               "defaultuser" => "postgres",
               "dbuser" => [
                             "nagios"
               "showtime" => 1,
               "timeout" => 30,
               "action" => "connection"
Starting run_command with: SELECT version() AS v
Created temporary pgpass file /tmp/YgKJCf3LDf/check_postgres.SgqNHDfJ.tmp
$POSTGRES1 = [
               "-q",
               "-t",
               "-d",
               "postgres",
               "-U",
               "nagios",
               "-p",
               5439,
               "-h",
               "10.211.209.164",
               "-o",
               "/tmp/YgKJCf3LDf/check_postgres_psql.JRfhIfl.tmp",
               "-x",
               "-c",
               "BEGIN;SET statement_timeout=30000;COMMIT;SELECT version() AS v"
$POSTGRES1 = {
               "hosts" => 1,
               "db" => [
                           "dbpass" => "XXX",
                           "dbservice" => "",
                           "port" => 5439,
                           "dbname" => "postgres",
                           "host" => "10.211.209.164",
                           "ok" => 1,
                           "dbuser" => "nagios",
                           "totaltime" => "0.08",
                           "slurp" => [
                                          "v" => "PostgreSQL 11.5 on x86_64-pc-linux-gnu, compiled by gcc (GCC) 4.8.5 20150623 (Red Hat 4.8.5-36), 64-bit"
                           "pname" => "port=5439 host=10.211.209.164 db=postgres user=nagios"
               "command" => "SELECT version() AS v"
POSTGRES_CONNECTION OK: DB "postgres" (host:10.211.209.164) (port=5439) version 4.8.5 | time=0.08s
This is a no working trace once SSL activated on the remote postgres
$POSTGRES1 = {
               "verbose" => 3,
               "test" => 0,
               "transform" => "",
               "dbpass" => [
                             "XXX"
               "showperf" => 1,
               "port" => [
                           5439
               "dbname" => [
                             "postgres"
               "host" => [
                           "10.211.209.164"
               "dbuser" => [
                             "nagios"
               "showtime" => 1,
               "timeout" => 30,
Created temporary pgpass file /tmp/AbdD4WKgRy/check_postgres.UaYeZcJT.tmp
$POSTGRES1 = [
               "-q",
               "-t",
               "-d",
               "postgres",
               "-U",
               "nagios",
               "-p",
               5439,
               "-h",
               "10.211.209.164",
               "-o",
               "/tmp/AbdD4WKgRy/check_postgres_psql.SiTT1tc.tmp",
               "-x",
               "-c",
System call failed with a 512
ERROR: authentication method 10 not supported
Thanks for the info @steph007! We will try to lab this in-house, and find a solution for you. In order to do this, we need a little bit more information.
1. What is the OS/architecture of the machine with the remote postgres database on it?
2. Describe in details how you configured SSL on the remote postgres
Thank you!
steph007
Post by steph007 »
The remote machie is a Linux RedHat with postgres version 12.
The problem is if we enable MD5 encryption of the pw on the database side. Once it's done, with psql version 8, it cannot handle it correctly. If we remove the MD5 encryption of the pw on the database side, it's work well.
To fix the problem, I have installed postgresql11 from postgres repository. See below.
root@plgesmon02[/root]# yum list installed | grep postgres
postgresql.x86_64 8.4.20-8.el6_9 @updates
postgresql-libs.x86_64 8.4.20-8.el6_9 @updates
postgresql-server.x86_64 8.4.20-8.el6_9 @updates
postgresql11.x86_64 11.9-1PGDG.rhel6 @pgdg11
postgresql11-libs.x86_64 11.9-1PGDG.rhel6 @pgdg11
This has been add to the actual postgres installed. Not a overwrite. So, it should be good.
and now I can connect to my postgres database with MD5 encrypted password!
Great! I am glad you've been able to resolve the issue! Thanks for sharing the solution on the forum! This may help other users facing the same problem. Let us know if it is safe to lock this thread now.
