Tactical Summary Reporting host in pending state
This support forum board is for questions relating to Nagios Fusion.
bpennin
Re: Tactical Summary Reporting host in pending state
Post by bpennin »
3rd of five
bpennin
Post by bpennin »
4th of 5
bpennin
Post by bpennin »
5th
ssax
Dreams In Code
Post by ssax »
There were some XML bugs in XI 5.7.0-5.7.1, I would upgrade to XI 5.7.3 and test. If that doesn't fix it, it's likely the new NDO3 that is causing the issue.
Attach your /etc/php.ini as well.
Please PM me a copy of your profile from your XI server so I can investigate, you can download it from Admin > System Profile by clicking the Download Profile button.
bpennin
Post by bpennin »
Profile and php.ini from the Fusion server and Nagios XI server. Note - I had to back level the NDO to 2.x due to it not working after the upgrade. I hesitate to move to 2 or 3 due to the same problem being reported. Do you have any insight on that?
bpennin
Post by bpennin »
php.ini from Fusion
bpennin
Post by bpennin »
PHP.INI from Nagios XI
ssax
Dreams In Code
Post by ssax »
That's entirely up to you, I would upgrade to XI 5.7.3 and then re-downgrade your NDO3 back to NDO2. Or you can wait to upgrade to XI 5.7.4 when it comes out which will leave your NDO2DB downgrade in place (this was a development decision).
If you go to XI 5.7.2 or 5.7.3 you'll need to re-downgrade NDO3 back to NDO2DB, if you go to XI 5.7.4 it will leave you downgraded.
bpennin
Post by bpennin »
Did you see anything in the profile or php.ini files?
ssax
Dreams In Code
Post by ssax »
They both look good, given that you already have NDO3 downgraded to NDO2DB on this system (I verified in the profile) you'll need to upgrade to XI 5.7.3 (and then re-downgrade NDO3 back to NDO2DB) and see if that resolves it for you or wait until XI 5.7.4 is released and upgrade to that.
If you decide to go to XI 5.7.3 first, you can use these downgrade instructions after you've upgraded to XI 5.7.3:
Run these commands as root:
systemctl stop nagios
cd /tmp
rm -rf /tmp/nagiosxi
wget https://assets.nagios.com/downloads/nagiosxi/5/xi-5.6.14.tar.gz
tar zxf xi-5.6.14.tar.gz
cd /tmp/nagiosxi
./init.sh
cd /tmp/nagiosxi/subcomponents/ndoutils
./install
systemctl enable ndo2db
systemctl start ndo2db
Then edit your /usr/local/nagios/etc/nagios.cfg and make sure this line is uncommented:
broker_module=/usr/local/nagios/bin/ndomod.o config_file=/usr/local/nagios/etc/ndomod.cfg
Make sure all occurrenes of this line are commented:
#broker_module=/usr/local/nagios/bin/ndo.so /usr/local/nagios/etc/ndo.cfg
Then start the nagios service:
systemctl start nagios
