Performance Graphs- Warning and Critical Toggle
esostarich
In looking at the performance graphs, there seems to be only some metrics that have the warning and critical threshold toggle available (i.e. CPU Usage). Is it possible to have these toggles on all of the performance graphs that have thresholds (i.e. Disk Usage)?
Re: Performance Graphs- Warning and Critical Toggle
What plugin are you using for your Disk Usage checks? Please send a screenshot of Home > Service Status > click on the service > Click the + (advanced tab) so we can see what the performance data shows.
Do the ones missing them show more than a single metric? If it returns more than one metric I don't think those toggles will be shown.
esostarich
We are using the ncpa for disk usage checks. Please see the attached file for the requested screenshot.
The status information output is as follows: Used disk space was 60.00 % (Used: 13.79 GiB, Free: 9.19 GiB, Total: 22.98 GiB). The thresholds are related to this 60.00% value.
This is because it is returning multiple metrics, graphs will multiple metrics do not show the warning/critical toggles. I can submit a feature request on your behalf for development to have them add that functionality but the way it's currently coded if there is more than one metric returned they are not shown.
esostarich
Thank you for the explanation. Yes, please submit a feature request.
I have submitted the feature request:
FR: XI - Add warn/critical toggles for checks with multiple metrics, it currently only shows them if there a single metric
Please keep in mind that the decision to implement the enhancement is at the discretion of our development team.
Thank you!
Thank you!
