Hi, I need to add my service account as part of the setup of this wizard but there is a space and an apostrophe in one of my OU names. I have tried to encapsulate with inverted comma's as well as internal encapsulation but no joy as yet.
Here is what I have put:
Base DN for user account
"OU=Service Account's,DC=company,DC=local"
User DN
"CN=svc-nagios,OU=Service Account's,DC=company,DC=local"
The error I get is:
Info:Could not search/find objectclasses in OU=Service
Date/Time: 2020-11-04 14:37:31
Any help or guidance would be greatly appreciated!
Active directory monitor wizard - LDAP encapsulation
chris.robertson
Re: Active directory monitor wizard - LDAP encapsulation
I'll lab this up to test, but to be clear, you're getting this error when you run the check that the wizard creates and not in the actual wizard itself, correct?
chris.robertson
Thanks bud, yes this is when the monitor task runs, the wizard completes successfully but we have a space and apostrophe in the name of the OU "Service Account's" and the error states 'Service' which means that the space is causing the issue but likely the apostrophe would too. (I didn't create the OU but cannot change it now).
Much appreciated!
Much appreciated!
It seems to work on my system. Are you seeing the problem when you use the 'Run Check Command' button or do you see it in the dasboard? What happens if you try to run it on the command line? For example:
Note that I had to put the password in single quotes. You may need to to the same.
/usr/local/nagios/libexec/check_ldap -H 192.168.55.5 -b "dc=acme,dc=local" -D "cn=svc-nagios,ou=Service Account's,dc=acme,dc=local" -P 'password'
